Home > Wheels & Tyres > 235 or 265?
Co1
235 or 265?
Need some new tyres, BFG on he cards but to go 235 or 265. Other than width, what will the impact be on handling, fuel economy and turning circle? I donโ€™t have wheel spacers.
Post #734561 13th Oct 2018 6:36pm
JOW240725
235 will give slightly better turning circle and I guess marginally better mpg. I went with 265, purely looks really, maybe better high speed cornering? James
Instagram @suffolk_rovers
Post #734563 13th Oct 2018 7:06pm
Co1
Thanks James.
Post #734564 13th Oct 2018 7:08pm
265's will have an impact on turning circle - you may have to adjust the lock stops to prevent rubbing. I doubt you'll be able to tell the difference in terms of handling and fuel economy, though. Darren
Post #734565 13th Oct 2018 7:08pm
Co1
Thanks all. Would 265โ€™s be 265 75 16?
Post #734568 13th Oct 2018 7:16pm
Yes, that's right. Darren
Post #734569 13th Oct 2018 7:18pm
JOW240725
265x75R16 or 235x85R16 have pretty much same standard rolling circumference. James
Post #734571 13th Oct 2018 7:18pm
justinp
Surprisingly my mpg improved slightly when I went from 6 year OE continental 235/85r16 to brand new BFG 265/75r16.
I had to adjust my steering lock stops which I had previously adjusted to give me the best turning circle on the 235โ€™s, but I suspect if I hadn't adjusted it before, it would probably have been fine with the 265โ€™s. Now gone - 2012 2.2 110 DC XS
Post #734576 13th Oct 2018 8:00pm
williamthedog
Put 265s on mine when it was about 6 months old. Didn't adjust the stops and has been fine. Bfg a/t spring/summer, Bfg mud autumn/winter. Thumbs Up
Post #734581 13th Oct 2018 8:30pm
You can go 255/85/R16 with out spacers and just a little steering lock stop adjustment if you wanted to.
Depends if that tyre size is available at the moment, I'm guessing maybe not or not yet? $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #734582 13th Oct 2018 8:33pm
255/85 is only available as KM2, whereas 235/85 and 265/75 are available as KO2, KM2, and possibly KM3.
Post #734592 13th Oct 2018 9:44pm
Not sure about the KO2 ATR in 255/85 but I heard the KM3 will be shortly in that size but likely not just yet. $W33T $0U7H3RN $UG4R
Post #734665 14th Oct 2018 12:04pm
Co1
Thanks guys, 265โ€™s ordered.
Post #734666 14th Oct 2018 12:05pm
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Hi All, just picking up on this thread. I have heard that 265's are too big for standard alloys on ddci 2007, is there any truth in that? just making my decision and wanted to double check as I had not heard this previously Sweatysock
110 CSW TDCI (Puma) 2007
Post #745877 15th Dec 2018 6:18pm
WindyJ
BFGoodrich quote 7โ€-8.5โ€ for rim size with 8โ€ the recommended. I believed the boost alloys are 7?
Post #745878 15th Dec 2018 6:29pm
