Home > Maintenance & Modifications > Grass seeds in radiator
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
As the title suggests. Driving through long grass over summer has meant I have a lot of grass seeds jammed into the radiator. See Picture below.
1. Is this a problem.
2. How do I get them out?
Thanks
Post #732148 1st Oct 2018 10:18am
geobloke
Try back flushing the rad from the fan side. Not too much pressure though.
There is a Land Rover "chaff" guard to help prevent this sort of radiator clogging issue when driving through long grass; MTC4220.
https://rimmerbros.com/Item--i-MTC4220
Post #732162 1st Oct 2018 11:12am
Slideywindows
Phew, they've gone up in price!
When I bought a new one from Blanchards four years ago it was about £60.
The original, very early chaff guard seems to be a different design to the Rimmer Bros offering, with smaller holes than the new replacement item:
Post #732276 1st Oct 2018 7:22pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I have a feeling that the chaff guard on my 86in which my son now looks after has an even finer mesh, I doubt any grass seeds could get through it.
Post #732334 1st Oct 2018 10:04pm
NickMc
Nearly sure I’ve some of those Chaff guards tucked away.....somewhere Rolling with laughter
Post #732342 1st Oct 2018 11:20pm
geobloke
Of course it would not be a difficult job to actually make something like this for yourself, or get your local fabricator to if you wanted a finer mesh.
Post #732364 2nd Oct 2018 7:36am
Re: Grass seeds in radiator
Thanks
1. Yes, it can be if it impedes airflow to a significant extent, or the seeds start growing!
2. Careful use of compressed air from the backside of the radiator.
Post #732367 2nd Oct 2018 7:41am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Powerful vacuum cleaner might work
Post #732430 2nd Oct 2018 10:47am
Post #733033 5th Oct 2018 7:19am
andrewlandy
Thanks..........
....all. Not sure I have the patience for the fin tool, so compressed air it is.
Post #733669 8th Oct 2018 6:18pm
Vacuum worked on mine, but does need to be a good power and used accurately.
Anything that wouldn't shift, air from the rear asBW suggested would probably be best as BW mentioned.
You'd be surprised what gets in there grass seeds aside.
I've known parts of insects, a feather or two. Spiders webs inc spider parts.
Nearly always sommeging wasp related, either that or in the airbox or down the air duct into the cab whilst driving along. Shocked TheThunder Rolls🇬🇧🇺🇸
Post #733737 8th Oct 2018 11:14pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I had to take the front grill off recently and found seeds, wasps, flies etc in the fins used a vacuum to clear them out. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #733795 9th Oct 2018 10:32am
