Home > eBay & Bargain Spots > 1984 Factory Soft Top. |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1283 |
First time I've seen another Sept '84 factory soft top like mine (except this is a diesel) on eBay.
It's no looker and its MOT history is chequered, but it's reasonably cheap and might (ought to) sell even cheaper. https://www.ebay.co.uk/itm/Landrover-Defen...SwJGdbtgSr Could be a punt, instead of scratching your nice new Defender on a green lane, or converting it to a soft top? |
6th Oct 2018 8:37pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
I don’t think it’s a factory soft top, has had a rear door at some stage, evidence the tie down points are added later (rivets not painted), I’m fairly confident she started life as a hard top
6th Oct 2018 9:24pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Well worth it with a rebuilt 300tdi in it
6th Oct 2018 9:59pm |
Thanks for the input gentlemen.
So I'm still looking for another 1984 factory soft top. |
7th Oct 2018 9:19am |
To be honest, I don’t think I’ve ever seen a factory one (that’s not military anyway) or much later.
7th Oct 2018 6:08pm |
Well I actually washed mine today. Was so surprised to see it clean that I took a picture.
Click image to enlarge I think you've seen mine before Jeremy. Sept '84, 2.25 petrol soft top from new I believe, as there are no marks or holes for anything else to have been fitted.(I've had two rivet counters inspect it! ) The son of the first owner said his dad bought it to tow a boat to the South of France, hence the soft top, comfy County seats and repeaters in the front wings for those French motorways. |
7th Oct 2018 8:43pm |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 378 |
Oh dear. Date tested 12 December 2017 PASS Mileage 132,542 miles MOT test number 9558 4298 9799 Expiry date 11 December 2018 Advisory notice item(s) Offside Rear Direction indicator slightly discoloured (1.4.A.2f) Nearside Front Direction indicator slightly discoloured (1.4.A.2f) Nearside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a) Offside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a) Steering box has a slight oil leak (2.2.D.2e) Nearside Front Track rod end ball joint has slight play rear (2.2.B.1f) Oil leak () Offside Front Radius arm rubber bush deteriorated but not resulting in excessive movement both front bushes (2.4.G.2) Nearside Rear Rear wheel bearing has slight play (2.6.2) Offside Rear Rear wheel bearing has slight play (2.6.2) Nearside Body has slight corrosion floor (6.1.B.2) Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3) Date tested 11 December 2017 FAIL Mileage 132,542 miles MOT test number 4388 2015 4010 Reason(s) for failure Exhaust has a major leak of exhaust gases tail pipe (7.1.2) Advisory notice item(s) Offside Rear Direction indicator slightly discoloured (1.4.A.2f) Nearside Front Direction indicator slightly discoloured (1.4.A.2f) Nearside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a) Offside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a) Steering box has a slight oil leak (2.2.D.2e) Offside Front Ball joint dust cover damaged, but preventing the ingress of dirt drop arm (2.2.C.1c) Nearside Front Track rod end ball joint has slight play rear (2.2.B.1f) Oil leak () Offside Front Radius arm rubber bush deteriorated but not resulting in excessive movement both front bushes (2.4.G.2) Nearside Rear Rear wheel bearing has slight play (2.6.2) Offside Rear Rear wheel bearing has slight play (2.6.2) Nearside Body has slight corrosion floor (6.1.B.2) Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3) Date tested 5 July 2016 PASS Mileage 129,253 miles MOT test number 5463 2291 4857 Expiry date 4 July 2017 Date tested 1 July 2016 FAIL Mileage 129,253 miles MOT test number 9270 6340 5949 Reason(s) for failure Centre Exhaust system not adequately supported (7.1.1) Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3) Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3) Offside Headlamp aim too low (1. |
7th Oct 2018 8:54pm |
