![]() | Home > Td5 > Givin the ecu more power |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
I did get gwyn lewis’ light weight steerin rods, and sure i should check my weight but i have seen others runnin heavier and gettin away with more.
My fuel pump is to arrive on wednesday, will swap it out as well as the crank sensor and see if my illments go away and i have more power to play with. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2193 ![]() ![]() |
So what is the full "spec" list performance wise on your landy? Instagram @defender_ventures
Empire Tuning - Agent |
102mm inlet with modified airbox
Vdo maf sensor Silicone hoses Jose gt2556v turbo Alive ultimate intercooler Egr delete kit Prometh 2.5” mist a pipe Alive map sensor Ported intake manifold Ported head Ported exhaust manifold 3” downpipe 3” resonator 2.75” straight through system Ashcroft r380 overhaul kit V8 r380 5th gear Ashcroft lt230 master rebuilt kit Wildcat double cardan front propshaft Wildcat 3” wide angle rear propshaft Detriot tru lock diff Rakeway brake kit Ome springs Fox racing shocks Airbagman rear airbags Cargo bear roof rack Go rhino bed rack and grag rails Spectre front bumper 10k front winch with syn rope Safety devices inner roll cage And a few other cosmetic upgrades |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Naf bin the Rack, does wonders for MPG.
You tried having a dual Air feed? Like a 200TDI front left fender and running into a dual feed airbox? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Duel feed boxes create turbulant air flow a mess with the sensor readings. 102mm intake is far better.
Has it been remapped? Instagram @defender_ventures Empire Tuning - Agent |
