Home > Td5 > Givin the ecu more power
Page 2 of 2 <12
bankz5152
lightning wrote:
I thought the 110 was two tons not three?
I agree the standard TD5 is left wanting particularly on hills, so a bit more power is welcome. I’d like to fit an overdrive for motorway use. I tried a 90 with a Disco transfer box but l found reverse gear too high, it’s a good option though as it is fairly cheap to do.
Cage, sliders, HD everything + tools. Weighty landy Instagram @defender_ventures
Empire Tuning - Agent
Post #732925 4th Oct 2018 1:31pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
I did get gwyn lewis’ light weight steerin rods, and sure i should check my weight but i have seen others runnin heavier and gettin away with more.
My fuel pump is to arrive on wednesday, will swap it out as well as the crank sensor and see if my illments go away and i have more power to play with.
Post #733156 5th Oct 2018 6:22pm
bankz5152
So what is the full "spec" list performance wise on your landy? Instagram @defender_ventures
Post #733211 5th Oct 2018 10:02pm
Naf
102mm inlet with modified airbox
Vdo maf sensor
Silicone hoses
Jose gt2556v turbo
Alive ultimate intercooler
Egr delete kit
Prometh 2.5” mist a pipe
Alive map sensor
Ported intake manifold
Ported head
Ported exhaust manifold
3” downpipe 3” resonator
2.75” straight through system
Ashcroft r380 overhaul kit
V8 r380 5th gear
Ashcroft lt230 master rebuilt kit
Wildcat double cardan front propshaft
Wildcat 3” wide angle rear propshaft
Detriot tru lock diff
Rakeway brake kit
Ome springs
Fox racing shocks
Airbagman rear airbags
Cargo bear roof rack
Go rhino bed rack and grag rails
Spectre front bumper
10k front winch with syn rope
Safety devices inner roll cage
And a few other cosmetic upgrades
Post #733325 6th Oct 2018 2:05pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Naf bin the Rack, does wonders for MPG.
You tried having a dual Air feed? Like a 200TDI front left fender and running into a dual feed airbox? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #733326 6th Oct 2018 2:19pm
bankz5152
Duel feed boxes create turbulant air flow a mess with the sensor readings. 102mm intake is far better.
Has it been remapped? Instagram @defender_ventures
Post #733415 7th Oct 2018 7:37am
Page 2 of 2 <12
