Home > Puma (Tdci) > Steering noise at low speed or manoeuvring
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
My car has what can only be described as a grinding feeling and noise through the steering system when manoeuvring. I have been told it’s normal and there is a LR bulletin that describes it being caused by harmonics in the fluid system.
My mechanical sympathy is really struggling with this.
Anyone else got this or know more about it? Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #732989 4th Oct 2018 8:13pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Could it be like a bubbling?? mine sounds like bubbles at high pressure and that is the high pressure oil circulating.
other grinding noise could be the tyre with the frame, you could see that marks on the frame Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #733018 4th Oct 2018 11:20pm
Stu_XS
No I don’t think it’s bubbles nor hitting the chassis as it happens randomly through the cycle. Stu...
Post #733029 5th Oct 2018 6:36am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine has always made a weird humming noise at rest or when doing a slow manoeuvre whilst turning the steering to the left. It feels and sounds like something to do with the hydraulic system rather than mechanical. 1953 80"
1987 mini city e
2011 90"
Post #733074 5th Oct 2018 11:12am
Morepower
New Zealand
If it's still under warranty take it into the dealers... My 90 did this.. Turns out some steering pipes needed different brackets to stop the pipe vibrating (which causes the noise your hearing)...
Hope this helps
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #733239 6th Oct 2018 8:17am
Stu_XS
Thanks Tim but it's not under warranty.
I have been told here is a bulletin on the subject but I don't seem to be able to find it. Stu...
Post #733273 6th Oct 2018 9:54am
Stu_XS
I found a bulletin but it seems to be for V8 models and suggesting to change the pipe from box to reservoir.
I'm wondering if it could be a UJ on the column or one of the ball joints on the steering system so I think I am going to invest in the Terrafirma HD kit which includes greaseable ball joints. Stu...
Post #733298 6th Oct 2018 11:43am
