Home > Puma (Tdci) > Steering noise at low speed or manoeuvring |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Could it be like a bubbling?? mine sounds like bubbles at high pressure and that is the high pressure oil circulating.
other grinding noise could be the tyre with the frame, you could see that marks on the frame Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
4th Oct 2018 11:20pm |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 |
No I don’t think it’s bubbles nor hitting the chassis as it happens randomly through the cycle. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma |
5th Oct 2018 6:36am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
Mine has always made a weird humming noise at rest or when doing a slow manoeuvre whilst turning the steering to the left. It feels and sounds like something to do with the hydraulic system rather than mechanical. 1953 80"
1987 mini city e 2011 90" |
5th Oct 2018 11:12am |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
If it's still under warranty take it into the dealers... My 90 did this.. Turns out some steering pipes needed different brackets to stop the pipe vibrating (which causes the noise your hearing)...
Hope this helps Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
6th Oct 2018 8:17am |
Thanks Tim but it's not under warranty.
I have been told here is a bulletin on the subject but I don't seem to be able to find it. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
6th Oct 2018 9:54am |
I found a bulletin but it seems to be for V8 models and suggesting to change the pipe from box to reservoir.
I'm wondering if it could be a UJ on the column or one of the ball joints on the steering system so I think I am going to invest in the Terrafirma HD kit which includes greaseable ball joints. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
6th Oct 2018 11:43am |
