Home > In Car Electronics > Radio sometime is getting what sounds like interference
Stacey007
Hello
My radio recently is picking up some sort of interference from some other electrical bits in the car? Crackling and just making an odd sound every now and again?
How can I fix this, do I need to add a suppressor? and if so what and how do I wire this in.
edit to add I've just noticed these and given I don;t like messing with electrics would these work on the cables?
https://www.amazon.co.uk/Topnisus-Anti-int...r&th=1
Thanks
Scott
Post #733066 5th Oct 2018 10:38am
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Poor quality lights will do this. Is it an analogue or digital radio? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #733071 5th Oct 2018 11:00am
Stacey007
Hello
Its a Digital radio I swapped from an analogue one. With a digital aerial
The lights are wipac crystals with upgraded bulbs (have been on 18 months)
Post #733073 5th Oct 2018 11:09am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
USB ports will also cause interference. Need a common mode choke or suppressing bead on the cable
Post #733090 5th Oct 2018 12:15pm
Stacey007
Kmac
what is one of these, as I plug my phone into the USB port to use Android auto...
Post #733107 5th Oct 2018 2:06pm
kmac
A common mode choke is a ferrite ring with copper coil and a capacitor on each end
Have a look at this thread which gives a detailed explanation of how to make one.
http://www.defender2.net/forum/topic26844.html
You can also get ferrite rings such as in the pic below but they some have said they are not so effective ( they clip over the cable supplying power to the USB port)
Post #733257 6th Oct 2018 9:09am
EastFreo
Australia
I was getting interference and found it was coming from using a USB charger in the cigarette lighter socket. Changed over to a new one and it was cured.
Post #733614 8th Oct 2018 2:01pm
jst
Or it's coming from your phone ! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #733619 8th Oct 2018 2:40pm
Stacey007
Hello
This is my set up, The Head unit has a USB input and I have a lead from the back of this to in front of the cup holder with a USB port I can plug in.
I use a short USB to USB C lead to connect my phone to the Unit and then Android auto starts.
I tried unplugging my phone and it still did it. how else can I eliminate what it could be? I'm tempted to get the ferrite rings and try them on the usb cable? from the head unit to where I plug the phone in.
Post #733621 8th Oct 2018 3:03pm
kmac
"...from the head unit to where I plug the phone in"
yep this could be where the interference is coming from as even if the phone is not plugged in there is a step down transformer converting 12v to the 5v needed for the USb socket. This is drawing current all the time power is supplied to the stereo.
You can try the ferrite rings to see if they make a difference - they are only a quid or two. They don't always work, you could try folding the cable on itself a few times and then the ferrite ring over the folded part.
Post #733768 9th Oct 2018 8:30am
Stacey007
I have tried it driving home and back into work without the phone 'plugged' into anything
Still interference?
Is it still the cable causing and issue? I can unplug the phone cable as that's easy but the other one is wired from back of head unit under carpet to the cup holder.
Is one of those ferrite rings worth a try on this USB lead
Post #733987 10th Oct 2018 8:54am
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I was getting this quite a bit after having my tracking installed with the issue being that whenever it sent a notification of my location, which was random, I had said interference. Won't go into specifics on the fix as it has to do with the tracker, but if you have one, that could be it.
I still get it once and awhile but it last 2-5 secs and now that I know what it is, i find it comforting that it gives me piece of mind the kit is working Wink
Good luck
P
Post #736599 25th Oct 2018 5:06am
