![]() | Home > Maintenance & Modifications > 90 Ride Comfort |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I literally did it with articulation last month all four corners?
I'm guessing you have ARB or something which is limiting it 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Yes, I'd agree likely the ARB which should be un-bolted first. WeWillWin🇬🇧🇺🇸
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Exactly right. The arbs stop the articulation. If you don’t have the spring compressors then unbolting the arbs would probably work. I thought of this in the 4th spring, having already compressed it!
It would've worked without the ARB ![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Hindsight eh!! 👓
IIRC, I just unbolted the ARB to chassis and tied it up, nothing more to take off than that.
Then replace once done. Main thing is you got it done in the end compressors or not, definitely a job to be careful doing hat's for certain. ![]() ⛽️🛢️⚙️🧰💪 |
Yep, agree with Steve. Kudos for getting it done yourself
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Any pics of how it sits now with the new springs? The idea of a better ride certainly appeals, but I also tow a caravan 6 or 8 times a year. Would such a setup still be fine with the caravan on the rear of the 90? Watching with great interest 👍
I wouldn’t think this would be the thing to do if you do a lot of towing. I don’t do any towing and don’t carry much load hence ge move away from HD. The back is currently sitting a touch low.
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
I've can say the same, ive put 110 front progressives on the front and rear of my 90. It rides so much better! You can actually feel the axles moving over bumps. I would personally like it a touch stiffer for the corners so I'm going to put fox dampers all round which are gas shocks and should be slightly firmer than the knackered originals. These are being justified as I only spent £85 for all 4 springs brand new genuine take offs.
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
just looking at this again as ive just replaced my springs and you can do it without spring compressors or removing ARB. My drive is sloping so i cannot safely jack up both wheels. !.Remove turret cover 2.Jack up car on chassis axle stands for safety 3. Remove wheel 4.Jack under axle(bottle) of side your doing and support axle only. 5.Remove botton nut of shock(bracing shock with mole grips) 6.Remove turret nuts 7.lift out shock ant turret 8.lower jack on axle and remove 9.Place bottle jack on flat surface of bump stop on axle and jack up against chassis (pushing the axle down in controlled way)slowly in a controlled fashion being wary of brake hoses,springs will fall out ..no levering .pushing or shoving this should work for all except very long springs. ![]() Click image to enlarge I was surprised how controlled it was and if i can do it anybody can.Obviously there is limit to the articulation due to the brake hoses but it should work easily enough on all but the larger springs. |
Dick Member Since: 06 Jul 2023 Location: London / Devon Posts: 75 ![]() ![]() ![]() |
This is interesting, as im looking to replace my old, very rusty looking springs, with a set of the Britpart 'Light' duty 1" lift springs.
Very little information about or evidence of anyone that has used this kit. Front lifts by 25mm, rear lifts by 40mm and the spring weight is about 5kg down on the 'standard' defender springs. I have no 'accessories' pm the car to weigh it down and don't intend to be loading up particularly heavily. Does my logic make sense in thinking that this will soften the ride a little? Does anyone have experience with these springs? I'm just hoping im not going to be wallowing round corners, but surely 5kg less wight rating over a 220kg spring isn't going to have much difference! |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 511 ![]() ![]() |
Fox's wont make any difference to body roll around corners only ARB's or stiffer springs can help. |
Would avoid BP springs better to go with OME if you want a slight lift and less body roll |
