Home > Td5 > Electric Cooling Water pump |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
there was plenty on this a while back, personally i wouldnt fit one. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Oct 2018 12:46pm |
Duke851 Member Since: 02 Oct 2018 Location: West Sussex Posts: 13 |
Thanks, James.
I did a search but didn't find out anything, will try again later. |
2nd Oct 2018 12:52pm |
think it was on a 300tdi, will look later. Cheers
2nd Oct 2018 12:59pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Would the heater still work?? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
2nd Oct 2018 8:51pm |
Hi
Yes it should, if the pump is not running, then convection current flow should still flow to the heater because it will be cooler than the engine and the cold air flowing past the heater element should also help. I think........ |
2nd Oct 2018 8:58pm |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
If you are looking at improving mpg, then electric fan should be the first change, that uses more power than the electric pump.
I do like the idea of heating using the residual heat from the engine. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
2nd Oct 2018 9:15pm |
Hello Augusto
I will need to remove and fit an electric fan which will improve the mpg, the electric water pump controller will also switch the fans on. Many thanks |
2nd Oct 2018 9:32pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 622 |
Easiest way to improve MPG is change Defender for another car. Improvement like electric cooling pump will make the car less reliable. Standard proper working fan has nearly no influence on engine - with running engine it is just barely rotating - it is possible to stop it with a finger. If not, than it is stuck and needs replacement. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
3rd Oct 2018 5:34am |
Hello MadTom
Like everyone here, I choose to drive a Defender at every opportunity and have always wondered how can I improve my defender. An electric water pump should be reliable, after all the heater motor and cooling fans are electric and I've never had to replace either of them on any of my cars. |
3rd Oct 2018 2:00pm |
Many thanks for your comments.
Failure of heater fan = no heating, but not cooked engine.
Cooling fan - standard are belt driven, electric powered is the fan for A/C, failure of A/C fan = no A/C or lower A/C power, but not cooked engine, failure of cooling fan (belt driven) = probably big problem like broken belt or punctured water cooler. Broken electric water pump - probably cooked engine, or at least towing the car home. In average temperatures, it is not a problem, but my experience with using heavy Discovery od Defender with TD5 engine and travelling into mountains of south Europe in hot summer, the original belt driven fan has huge power, when fully engaged, it is like starting helicopter next to the car. It is not comparable to any "standard" electric powered fan. We had one car with electric fan, and it was not enough, after 2 days of problems with overheating, we managed locally an used belt driven fan, and all was fine. The belt driven fan is kicking only occasionally, but the cooling effect is much bigger when needed. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
4th Oct 2018 7:34am |
Good Morning MadTom
Many thanks for sharing your experiences with me, it makes a lot of sense. I am yet to travel that far and in such hot conditions, the last thing I want to do is create a vehicle that does not perform hence asking on a forum. |
4th Oct 2018 9:23am |
