Home > Puma (Tdci) > fuel starvation, unburnt fuel and no power.. Any ideas?
annette
Costa Rica
The electricity board 130 puma 2010, again. it wwas in for head gasket and blocked oil cooler
It starts fine now, engine is squeaking clean inside the manifold etc, fresh oil, fresh OEM filters (Mahle& Standadyne)
but as the title says .. no power.
We can't run it on the raod as the stupid ICE doesn't allow us to, you need a special permit
the one minute I had with their driver ..
fuel pressure was 1180 bar max
turbo 1.4 bar
revs don't go past 2800-3000
we disconneted the turbo rod and hand held it in a know good position.. not that, can rule it out
Egr was also disconnected
I get occasionally an injector learning error but I think I can translate this into pilot learning. Which is a sod to do if you can't really run here and i can hardly get the Cº past 75, takes about an hour of sitting in diesel fumes.
the images will hopefully show the oil cooler as it was Fixing Land Rovers in rural Guanacaste
Post #730894 24th Sep 2018 3:21pm
zsd-puma
what about if you put some cardboard in front of the radiator also switch on electrical loads.
Post #730912 24th Sep 2018 5:20pm
annette
Costa Rica
thank you
the airco on makes the 2nd fan run Smile
tried the cardboard still not much luck Fixing Land Rovers in rural Guanacaste
Post #730915 24th Sep 2018 5:44pm
annette
Costa Rica
it runs a bit better now after trying to do the Pilot learning about 47 times.
But it never completes the learning procedure. Aways abort with status 17 and error E7
Anyone know what this means? Fixing Land Rovers in rural Guanacaste
Post #731413 26th Sep 2018 8:13pm
NickMc
Using a quality Valve? had problems like this on aftermarket. Shouldn’t be hard to get it up to temp, would make me suspect of a false sensor reading.
Post #731434 26th Sep 2018 11:36pm
annette
Costa Rica
Ir is a good sensor and i have checked it with our temperature pistol. The head temperature is slightly higher.
Post #731515 27th Sep 2018 2:10pm
annette
Costa Rica
thanks to everybody, it is the VCV valve. Now waiting for the ICE (state company) to cough up another second hand one. Fixing Land Rovers in rural Guanacaste
Post #731783 28th Sep 2018 8:58pm
NickMc
Waste of time fitting second hand need to be clean clean clean
Post #731807 29th Sep 2018 12:19am
annette
Costa Rica
You are right but frankly we want them to pay for the head job and then they can come back for a new one.
Sick of arguing with 3 bureaucrats who don't know a VCV from a game for their phone.
and here is what the old one looked like
http://www.defender2.net/forum/viewtopic.php?p=731810#731810 Fixing Land Rovers in rural Guanacaste
Post #732225 1st Oct 2018 4:25pm
NickMc
Don’t worry I know the feeling well done a fair few utility buses over here and the battle with the bean counters never ends, not to mention actually trying to extract the money from them Laughing
Post #732229 1st Oct 2018 4:33pm
