Home > Puma (Tdci) > fuel starvation, unburnt fuel and no power.. Any ideas? |
annette Member Since: 24 Nov 2017 Location: Tilarán, Costa Rica Posts: 68 |
The electricity board 130 puma 2010, again. it wwas in for head gasket and blocked oil cooler
Click image to enlarge It starts fine now, engine is squeaking clean inside the manifold etc, fresh oil, fresh OEM filters (Mahle& Standadyne) but as the title says .. no power. We can't run it on the raod as the stupid ICE doesn't allow us to, you need a special permit the one minute I had with their driver .. fuel pressure was 1180 bar max turbo 1.4 bar revs don't go past 2800-3000 we disconneted the turbo rod and hand held it in a know good position.. not that, can rule it out Egr was also disconnected I get occasionally an injector learning error but I think I can translate this into pilot learning. Which is a sod to do if you can't really run here and i can hardly get the Cº past 75, takes about an hour of sitting in diesel fumes. the images will hopefully show the oil cooler as it was Fixing Land Rovers in rural Guanacaste |
24th Sep 2018 3:21pm |
thank you
the airco on makes the 2nd fan run tried the cardboard still not much luck Fixing Land Rovers in rural Guanacaste |
24th Sep 2018 5:44pm |
it runs a bit better now after trying to do the Pilot learning about 47 times.
But it never completes the learning procedure. Aways abort with status 17 and error E7 Anyone know what this means? Fixing Land Rovers in rural Guanacaste |
26th Sep 2018 8:13pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1620 |
Using a quality Valve? had problems like this on aftermarket. Shouldn’t be hard to get it up to temp, would make me suspect of a false sensor reading.
26th Sep 2018 11:36pm |
Ir is a good sensor and i have checked it with our temperature pistol. The head temperature is slightly higher.
Click image to enlarge Click image to enlarge Fixing Land Rovers in rural Guanacaste |
27th Sep 2018 2:10pm |
thanks to everybody, it is the VCV valve. Now waiting for the ICE (state company) to cough up another second hand one. Fixing Land Rovers in rural Guanacaste
28th Sep 2018 8:58pm |
Waste of time fitting second hand need to be clean clean clean
29th Sep 2018 12:19am |
You are right but frankly we want them to pay for the head job and then they can come back for a new one.
Sick of arguing with 3 bureaucrats who don't know a VCV from a game for their phone. and here is what the old one looked like http://www.defender2.net/forum/viewtopic.php?p=731810#731810 Fixing Land Rovers in rural Guanacaste |
1st Oct 2018 4:25pm |
Don’t worry I know the feeling well done a fair few utility buses over here and the battle with the bean counters never ends, not to mention actually trying to extract the money from them
1st Oct 2018 4:33pm |
