Home > My Defender > V8 90 Project |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Hi Retroanaconda, yes the mounts are the same and it’s the original box etc, was just wanting to confirm as you do have some adjustments with the mounts having the elongated mounting holes to the chassis, don’t really want to tighten it all down and find I’m a few mm out on the engine install. The axles have been swapped for 110 Wolf axles which I believe is the same as a p38 diff, I will have to hunt for the rear prop and mount it to check alignment
So next update: With a rough date of needing it a moveable condition by May 19 I do really need to get a move on so last weekend was a day it started to take shape: Click image to enlarge The old bulkhead is now fully stripped and the majority of metal parts have been cleaned and painted: Click image to enlarge Out with the old in with the new: Click image to enlarge You can make out the year of manufacture is 1987 so both wheel boxes were original fitment, shame to change them but the are rough and notchy. Favourite tool this week has to go to the sand blaster for turning bits like this: Click image to enlarge Into this: Click image to enlarge Hopefully some good updates to come over the next week or so once my gaskets etc arrive 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
24th Sep 2018 8:16pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10854 |
Nice to be moving forward a bit more now mash, the sand blaster is a great bit of kit to have, makes light work of all the rubbish on the items Clayton.
24th Sep 2018 8:42pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5224 |
looking more like a car that now mash! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
25th Sep 2018 5:06am |
Cheers guys is looking more 90ish but so much more to try and do
Well I have been able to do a few more bits on Maggie, it’s now at the stage of, clean paint and await of gaskets to fit, and then find bis you forgot to do so do them as well. Click image to enlarge Click image to enlarge There are times when you look at something and ask yourself what have you done : Click image to enlarge This is the point you walk away have a cuppa then come back to find it’s really easy And you end up with this: Click image to enlarge Click image to enlarge So she is getting there............ slowly 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
29th Sep 2018 7:41pm |
I to find it's best to go and have a cuppa and then come back to it, it really does make a difference
Nice bit of progress there Mash Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
1st Oct 2018 7:56pm |
Totally agree Clayton
Well it’s been a busy old week with some right jobs, nothing’s been simple and easy, oh well now it’s the weekend and I have time for Maggie So today was a few quick jobs, using up my little delivery of L/R gaskets and seals surprising how quickly the total adds up in your basket So what I managed to achieve, steering box that has been overhauled (well cleaned and painted) as I snapped 3 sets of circlip pliers trying to replace the lower seal so I guess Maggie will be one to mark her territory fitted brake and clutch pedal boxes, fitted 4 out of 6 bolts to my throttle pedal as 2 holes don’t line up (a-?-e strike again ) so not too bad for an hour or so tinkering, more to do tomorrow. Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
19th Oct 2018 8:04pm |
Nice bit of tinkering there Clayton.
22nd Oct 2018 8:21pm |
Well I do apologise for my absence, life has been getting in the way of my Land Rover time, well rebuild time that is, I have clocked up close to 1000mi in just over a month in the 110
So now I’m am back for a very short period and then off back to Guernsey for Xmas so this is the only update I have on Maggie So I have managed to find a few hours to tinker and have succeeded in producing a fully steering chassis Click image to enlarge Click image to enlarge I have also made a start on painting the wings, they have been primered and received their first top coat, not happy with the finish so wet and dry with another coat should give me the right finish. Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
15th Dec 2018 10:08pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Amazing work, it's going to be awesome!! Looks like you're on the home run now James
16th Dec 2018 8:35am |
Cheers James not on a home run yet though, still have the seat box back to strip and repair before paint, oh and the fuel system to fathom out as original pipes are shot and you can’t get them now, then there is brake lines, coolant pipe work etc still it could be worse, I could have 3 defenders and a Disco to keep me busy 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
16th Dec 2018 10:21am |
Oh well, you know what they say about idle thumbs!! James
16th Dec 2018 11:25am |
Yep mine cost me a fortune on evilbay 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
16th Dec 2018 5:07pm |
More spraying today, got a few other bits done so slowly getting there with the painting
Click image to enlarge Back off to Guernsey tomorrow so no more tinker time with Maggie for a few weeks. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
18th Dec 2018 10:54pm |
Certainly taking Maggie a bit more forward Clayton.
21st Dec 2018 9:39pm |
