Home > In Car Electronics > Central locking - locking / unlocking when opening door
nick345345
Scotland 2012 Defender 110 Puma 2.2 USW Baltic Blue
Hi all,
I’ve got a 2012 USW and the central locking seems to have acquired a life of his own. When I turn the car off, remove the key from the ignition and then go to open the door the central locking locks itself. It can also happen if I approach the car when unlocked and try to open the drivers door. Again the central locking locks itself. Never have any bother locking or unlocking the car with the fob itself.
I’ve done some searching and the closest information I can find suggests that the locking mechanism might need some lubricating. Is that where I should start? Or does anyone have any other suggestions?
Many thanks in advance,
Nick
Post #731033 25th Sep 2018 8:15am
GeeBee
United Kingdom 2012 Defender 110 Puma 2.2 USW Keswick Green
In the below zero weather we're having, I'm experiencing this too.
I unlock via the key fob and the central locking cycles through from lock to unlock repeatedly. I need to quickly open a door when it unlocks. The problem does away once the day warms up.
Did you ever get to the bottom of this? 2012 USW Keswick Green 110
Post #744250 5th Dec 2018 8:00pm
nick345345
Haven't managed to solve it yet. Though the problem has largely gone away for the last few weeks so I've forgotten about it...
Post #744270 5th Dec 2018 9:31pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Cold weather can play havoc with it.
Also check your wiring through the A and B pillars, small cracks or splits in the wiring sheath can set it off
Post #744271 5th Dec 2018 9:39pm
WindyJ
I had same thing. Sat inside and watched it from there and i could see the lock pegs struggling to move fully up so were flying straight back down. Put some oil on the plastic and they were back to normal as was everything else....
Post #744274 5th Dec 2018 9:47pm
grafty99
It could also be damaged wiring between the a pillar and door Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #744285 5th Dec 2018 10:38pm
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
I had the same problems earlier this year when we had all the snow. Took my niece to school, left the car running in the road while I jumped out to walk her across the road and as I shut the door - boom, locked out!
Thankfully one of the parents gave me a lift home to get my spare key, but boy did my defender cause a lot of traffic blocking the single land country road Embarassed
Post #747461 26th Dec 2018 9:05pm
nick345345
Quick update. I've finally managed to resolve the issue I was having. The part I've circled in the picture below was complete seized on the back of the lock barrel on the drivers door. Managed to get it off, free it up and grease it. And (for now!) the central locking seems to be behaving.
Post #761630 3rd Mar 2019 7:19am
Rich01483
Thanks for this, I had the same problem, everything else seemed to be fine so I’m glad this was the solution!
Post #954064 30th May 2022 11:56am
