Home > Maintenance & Modifications > Door seals |
shaun1968 Member Since: 30 Aug 2018 Location: Essex Posts: 65 |
Want to replace the door seals on my 1986 90, are they 1 piece ????..
Cheers Shaun |
21st Sep 2018 8:38pm |
Yes. Well, almost. The main seal is one piece that's shaped to fit along both sides and across the top. The bottom seal is a separate piece that's riveted or bolted (can't remember exactly) to the cill rail. Darren
21st Sep 2018 10:01pm |
Thanks very much, I will do some ordering tomorrow
21st Sep 2018 10:04pm |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Morning,
Mine's a 98 TDI 90, I replaced the door seals and they were the one piece as stated above (up one side, across the top and down the other side). The bottom bit is riveted to the door bottom. Cheers, Simon |
22nd Sep 2018 7:01am |
Land Rover updated the design in late 2010-2011 models, the newer ones work far better than a simple strip of rubber
23rd Sep 2018 7:20am |
So remove old style pop riveted to body, replace with new style pop riveted to door,,,,,,simples
23rd Sep 2018 7:28am |
