Home > Maintenance & Modifications > Door seals
shaun1968
United Kingdom 1986 Defender 90 2.5 n/a Diesel HT Eastnor Green
Door seals
Want to replace the door seals on my 1986 90, are they 1 piece ????..
Cheers Shaun
Post #730432 21st Sep 2018 8:38pm
Yes. Well, almost. The main seal is one piece that's shaped to fit along both sides and across the top. The bottom seal is a separate piece that's riveted or bolted (can't remember exactly) to the cill rail. Darren
Post #730444 21st Sep 2018 10:01pm
shaun1968
Thanks very much, I will do some ordering tomorrow
Post #730445 21st Sep 2018 10:04pm
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
Morning,
Mine's a 98 TDI 90, I replaced the door seals and they were the one piece as stated above (up one side, across the top and down the other side). The bottom bit is riveted to the door bottom.
Cheers, Simon Thumbs Up
Post #730461 22nd Sep 2018 7:01am
Land Rover updated the design in late 2010-2011 models, the newer ones work far better than a simple strip of rubber
Post #730600 23rd Sep 2018 7:20am
shaun1968
So remove old style pop riveted to body, replace with new style pop riveted to door,,,,,,simples
Post #730603 23rd Sep 2018 7:28am
zsd-puma
But they only fit the later steel doors, from about 2005 onwards, which have a different pressing.
Post #730667 23rd Sep 2018 1:15pm
