Home > Puma (Tdci) > Under my skin...
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Under my skin...
... Defender's skin i'd say. I have some rust bubbling under the paint on the A-pillars of my Oct 2007 def. Now, i have read several threads talking about long term warranties and so on, and i haven't been able to understan if the bodywork has a longer warranty than the mechanics. My car is obviuosly out of mechanical warranty but if it is true that there is a 6-years warranty on the bodywork i might still have hopes. Now the question: where do i check IF i have this warranty or not? Please help me figure this out.
Thanks in advance guys Smile
Post #73047 27th May 2011 10:42am
MK
In fact the bodywork warranty for corrosion is 6 years. Try to look into the service booklet or manual Puma 110" SW
Post #73048 27th May 2011 10:56am
mse
Yes the anti corrosion warranty is 6 years and its a perforation - so if its coming from underneath you should be covered
do a search - they sometimes put up some resistance Mike
Post #73060 27th May 2011 12:53pm
Yetiman
Great to know. My 07 is rusting on both doors and rear...all from under the paint and not on a join. I will pop in to Land Rover next week. Wish me luck!
Thanks for the tip...I had no idea!
mark She's not old...just older
Post #73069 27th May 2011 2:22pm
JSG
Key point with the six year anti corrosion (perforation) warranty is that you are supposed to get the truck inspected once a year. If this hasn't been done (and the book stamped) be prepared for some dealer wriggling.
Although if you use Lancasters in Reading you should be ok - they did the rear door on my 2000 TD5 CSW after four years without the stamps. John
2011 Tdci 110 CSW XS
Post #73142 27th May 2011 10:35pm
Grockle
as I mentioned on another thread,our 08 is in again for corrosion this time on the windscreen surround,rear gutter and L/H rear capping, they will repair it just stand your ground if the dealer can't be bothered to get the go ahead from LR 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #73167 28th May 2011 8:18am
