Home > Tdi > EGT Gauge Fitting
NAS90Noel
Portugal 1989 Defender 110 V8 Petrol HT Alpine White
EGT Gauge Fitting
EGT Gauge - I'm in Australia for a few weeks and have found an EGT gauge much cheaper then cost in UK. It comes with a sender that has a 1/8 NPT thread. Thread adaptors are also available. Anyone know if there is an existing threaded hole on a 300 TDI I can use, and what thread? Many thanks for any assistance. He who wanders is not always lost
Post #730034 19th Sep 2018 10:13pm
white110
Wales 1997 Defender 110 300 Tdi HT Alaska White
First thought was EGR blanking plate, drill and thread for adaptor.
How much depth does the sensor require ?
Post #730037 19th Sep 2018 10:59pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Jip. That's how mine was done. Then you give the thermocouple a slight bend to put the tip into and upwards into manifold.
Post #730046 20th Sep 2018 5:30am
Bps
This is what I used
Post #730047 20th Sep 2018 5:46am
geobloke
Not a 300tdi but a TD5. I fitted an EGT guage almost a year ago now and i have to say the thing that surprised me the most was just how much the temperature fluctuates and by how much. It is no wonder exhaust manifolds warp or studs break.
Well worth the effort to install. There are some good youtube videos out there IIRC for 300tdi installation. Just search for "300tdi egt gauge" and there is heaps of stuff out there.
Which gauge have you found?
Post #730064 20th Sep 2018 7:45am
Bps
This is what I use. Been reliable for the last 12 months or so
Post #730068 20th Sep 2018 7:55am
NAS90Noel
Thanks for all the ideas. I've found a gauge here at $160, it's cheaper then I've seen in Europe and is almost a match for the VDO gauges I already have fitted, and comes with sender. VDO gauge plus sender was really expensive option! I've already ordered the EGR plate with 1/8 NPT fitting from fleabay. So looks like I have my next job when I get home. Thanks again for all the assistance, much appreciated. He who wanders is not always lost
Post #731615 28th Sep 2018 7:35am
geobloke
Good luck Thumbs Up Thumbs Up
Which brand of gauge did you go for in the end?
Post #731633 28th Sep 2018 10:21am
