![]() | Home > Td5 > Front wheel bearings? |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Most likely you''ll need to reshim the upper swivel bearing.
Regards, Joris |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Get someone to press the brake pedal while you rock wheel. If it rocks whilst brake on it will be your swivels, if only when brake off, it will be wheel bearings. Wheel bearing movement will also be in all directions. So top to bottom, and side to side, swivel just top to bottom.
