Home > Maintenance & Modifications > What rear LSD
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
What rear LSD
I replaced my stub axles last weekend because they where worn and now the rear diff is leaking, so i'm guessing it's worn too.
Rather than refurbishing the old one, I am pretty much set on getting an LSD of some variety.
Any recommendations?
My 200 Tdi isn't going to see heavy offroading as it's more of a restoration project.
Has anyone used this guy before: https://www.megasquirt-v8.co.uk/diff_axle.php ? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #729589 17th Sep 2018 7:26pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
They have many excellent videos on YouTube showing the work they do and different diff options and types.
Post #729592 17th Sep 2018 7:41pm
Kit
Yeah I just wasn't too sure if he was still in business as the website is something straight out of the 90s but he does mention buying KAM stock and that was quite recent. 1993 200 Tdi 90 CSW
Post #729596 17th Sep 2018 7:51pm
Moneypit
Yes there still trading, spoke to Nigel last week about a 4 pin front diff build.
Post #729597 17th Sep 2018 7:53pm
Kit
I've emailed him, hopefully i'll get to have a chat with him tomorrow Thumbs Up 1993 200 Tdi 90 CSW
Post #729606 17th Sep 2018 8:22pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
if you're not going to be doing any heavy offroading then beefing up the diff will probably be a bit of a waste
I've always wanted to fit a Detroit TruTrack if my diff ever goes. It's totally automatic and mechanical, so fit and forget. No need to tell it went to lock, no need for an air compressor and a bit cheaper than an air locker.
Will make a big difference in the snow... although I've been advised not to fit one in the front as it makes wet roundabouts a bit... "interesting" Laughing 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #729618 17th Sep 2018 8:51pm
ickle
I ran a Detroit locker in the rear and a tru track in the front of my 100" and they were ace, self centering steering was brilliant, and I even ran to France and back with a 1 tonne trailer and a broken rear half shaft - only came to light as the parked me on a ramp for the crossing and the handbrake started to fail when the sea got rough!
Keith
Post #729629 17th Sep 2018 9:10pm
jst
Nigel has been around for a while doing lots of good work ( 'hybrid from Hell' on lr4x4), he used to work for KAM and may still have ties with them. His work is good as is mega squirt stuff.
Personally though i would go with Ashcrofts, after 15years of challenge competing and last 3years at Ultra4 you can see the benefit of going with a company that specialise in transmission components and stand by their products for 5 years warranty. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #729636 17th Sep 2018 9:28pm
Kit
I think he's an Ashcroft dealer, I've left my email very open ended to see what he recommends 1993 200 Tdi 90 CSW
Post #729648 17th Sep 2018 9:50pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I can highly recommend Nigel @ Xcess4x4 his attention to detail is insane.
I would go for the Ashcroft ATB if you're set on fitting an LSD, much better than a trutrac in my opinion. I would expect Nige to recommend the same or perhaps a 4 pin instead.
Post #729679 18th Sep 2018 6:51am
Kit
What's a 4 pin? 1993 200 Tdi 90 CSW
Post #729686 18th Sep 2018 8:13am
Defendermatt
A 4 pin is an open diff but stronger than original, it has additional planet gears that increase the strength and were fitted in the rear of V8 90's or special vehicles.
Post #729692 18th Sep 2018 8:31am
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Just to throw another name into the pot how about a Quaife torque sensing diff, I have run one of these for over 200k now with just one rebuild after about 150k where Quaife supplied me with the wearing parts foc.
Post #729693 18th Sep 2018 8:31am
Defendermatt
Quaife's are also 4x the price of the Ashcroft unit so for a vehicle that isn't used heavily then its probably a bit overkill.
I agree, the Quaife units are beautiful. Managed to pick one up for a reasonable price, the other is an Ashcroft.
Post #729736 18th Sep 2018 12:32pm
roel
Just to make something clearer: A Tru trac is a limited slip diff based on the priciple that a wormwheel can drive a cogwheel but a cogwheel cannot drive a wormwheel. It is still a limited slip as it transfer about 3 times the torque off the spinning wheel to the wheel with grip. A wheel in the air has zero grip so 3 x 0 = still 0
A Detroit locker is locker so all torque goes to the wheel with grip.
I have a Detroit locker in the rear axle and a tru trac in the front and yes you can feel the Detroit in the rear but I love it.
I use my 90 on the road and off-road.
 Roel
2003 90 Td5 (2009-now)
Post #729809 18th Sep 2018 8:00pm
