Home > Puma (Tdci) > What’s the cause?
pannawonica
Australia
What’s the cause?
2011 puma 2.4 dies when driving but starts instantly when stationary and runs well too the next event! Anyhow been busy tomorrow I will look deeper into it. I have checked the fuel filter for residual water, non found. Battery and earths and relay under drivers seat for security! Fault codes I have yet too do. My thinking it maybe the ignition switch or 10As , however being intermittent it is a little bit Big Cry Thumbs Up
Post #729172 16th Sep 2018 3:13am
pannawonica
Australia
Checked fault code P0234
P0100
P0623
P0623
P0200
would I be looking at an electrical supply failure because I always get P0234 and the others suggest this too me, could be the switch behind the barrel lock? Looked at the harness and although tight, looked in good order!
Post #729173 16th Sep 2018 3:58am
There have been a couple of reports of the ignition switch failing that have produced the symptoms you've described.
This might help but also read back through the rest of the quite long thread:
http://www.defender2.net/forum/post700627.html#700627 Darren
Post #729185 16th Sep 2018 7:24am
pannawonica
Australia
Much thanks for the heads up Thumbs Up Very Happy , I’m sure whilst I am having a couple of sherbets, I can digest the info in the thread! It’s that time of day over here! Laughing
Post #729195 16th Sep 2018 8:19am
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
What about the CVC valve?
Mine was dying while idle. Changing CVC did help. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #729237 16th Sep 2018 12:55pm
pannawonica
Australia
I did consider the VCV, but I have not ever had water in fuel event which hasten the demise of said valve. Fault codes point too an electrical problem and it is at the moment running perfectly, starting idling and runnning at speed. I forgot too indicate that I lost instrumentation during the problem. Thumbs Up
Post #729420 17th Sep 2018 2:55am
pannawonica
Australia
Problem solved! Thumbs Up well not exactly Censored I suffered a ‘fail too proceed’ moment at a busy junction with lights! Burger! Anyhow got the RAC towed too Jordan Rovertech Perth who put the textbook on the deafener straight away! The tech said as I requested the 10AS too be turned off, he stated it could be, but it was unlikely, but give her a try! He was right, after reset ran well for 10ks then pooped again! Yep! It was the ECU, one ordered about a week from eastern states! Josh the tech said the do a lot of work for the main Land Rover dealers because they cannot change defender ECU,S. He then showed me his collection of puma gearbox adapter shafts! Rolling with laughter Thumbs Up happy days!👍
Post #730041 20th Sep 2018 1:11am
