![]() | Home > Maintenance & Modifications > New look grill and headlight surrounds on 90 |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
In my opinion I think the OEM look is the best for your defender.
I f you have not done so change the headlamps to wipac crystals with uprated lamps and a headlamp relay. This also improves the look of the Defender and also improves the lighting no end. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 512 ![]() ![]() ![]() |
I would agree with above - the standard Defender grill is the best IMO. Replacement grill and headlight surrounds are available as a 3 part set on eBay for about £30 so much cheaper than a lot of aftermarket grills as well Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 ![]() ![]() |
Original is best.
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
![]() Click image to enlarge The twisted style can look quite nice, when done right 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Most of the grills I am seeing on ebay are black? Are they all black from new and need to be sprayed grey?
JD 2008 TDCi 2.4 XS CSW |
The Brunel grey ones were standard spec. on XS models. Darren
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1001 ![]() ![]() ![]() |
If you are after a Brunel grey grill and light surrounds I have a fairly new one I could sell you for £35 and am not far from Chippenham
![]() ![]() Click image to enlarge |
SOLD
![]() I'll PM you in a bit JD 2008 TDCi 2.4 XS CSW |
Like these MJN?
https://www.paddockspares.com/pm678-wipac-...ralia.html There seem to be a lot of options on ebay LoL JD 2008 TDCi 2.4 XS CSW |
Both my surrounds look like this.....rather rusty
![]() Click image to enlarge I am assuming that is not part of a new headlight purchase and is some sort of surround I need to order separately? I dont want to undo it to examine it as it might fall apart, is that what is holding the unit secure? JD 2008 TDCi 2.4 XS CSW |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3386 ![]() ![]() |
ciorrect, thats the retaining ring and wouldnt come with the replacement grilles or a new headlight.
they are only a few quid however and you can buy a new headlight bowl with the retaining ring for £12. just google "defender headlight bowl" |
You can also buy stainless versions of the rings (often called bezels) for around £30. Darren
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Yes I fitted stainless bezels to mine (black powder coated) - still like brand new.
Out of interest, what a bar are you thinking of removing? If a soft one I may be interested in taking it off your hands ![]() |
