Home > Puma (Tdci) > How much should a pair of drive members cost?
blimbug
United Kingdom 2009 Defender 110 Puma 2.4 SW Bonatti Grey
I’m wondering if my garage has made a mistake - how much should a pair of rear drive members cost?
Car is a 2009 tdci 110.
£18.00 or £180.00?
Thanks!
Post #728800 13th Sep 2018 5:31pm
I recently (a couple of months ago) bought a Bearmach kit that included bolts and gaskets for just under £20. Genuine ones will undoubtedly be a lot more but I couldn't say by how much. Darren
Post #728805 13th Sep 2018 5:54pm
Britpart or similar are about £5 each, other aftermarket brands from £7 to about £20 each, and genuine LR are £175.74 inc VAT each.
Ashcroft HD flanges are around £90 per pair and are better than genuine.
Part no is RUC105200 if you want to Google.
So if you got a pair of genuine flanges for £180 you perhaps got a bargain! Shocked
Post #728807 13th Sep 2018 6:13pm
NickMc
The cheap aftermarket ones are not worth fitting- I refused to because I don’t want to do it over.
Does the bill not break it down into parts and Labour?
Post #728853 13th Sep 2018 11:57pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
That seems a bit steep - could they have fitted the single piece shafts like these?
https://www.ebay.co.uk/itm/LANDROVER-DEFEN...Swa3BbXweC
Post #728868 14th Sep 2018 7:23am
I am sure that they could (assuming that it was the rear axle, of course) but those are £350 each inc VAT from a dealer.
Post #728870 14th Sep 2018 7:41am
blimbug
Thanks for all the responses.
It turns out they used genuine parts, hence the price difference vs. after market.
Post #728968 14th Sep 2018 6:08pm
The two best options really putting cost aside are Genuine 1piece which are the most pricey or two piece Ashcroft
HD and Ashcroft HD flanges.
I don't see much point in cheap flanges, they'll just induce more wear more quickly on halfshafts splines which are considerably more expensive.
Both options as Blackwolf above suggested to me originally will give you high mileage capability.
Factory fitted two piece on mine lasted 60k which isn't bad though.
Much depends on your use and miles, but they are quite costly even more so on the front. Chillin In The Backwoods🇬🇧🇺🇸
Post #728983 14th Sep 2018 7:09pm
Scotm
£180 is a shocking price when Ashcroft claim to sell genuine for £30
https://www.ashcroft-transmissions.co.uk/d...05200.html
Post #729059 15th Sep 2018 9:24am
I would not be at all surprised if they aren't the same part. Chillin In The Backwoods🇬🇧🇺🇸
Post #729061 15th Sep 2018 9:59am
