Home > Puma (Tdci) > X-eng handbrake? |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Drum brakes went out with the horse and cart |
14th Feb 2009 10:15pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7877 |
Sonic, i have had to reread that line a few times to try and understand whats meant. i think mse means the handbrake only, ie how many defenders use x brakes and how many use drum brakes for handbrakes and how many problems do you here of for both types, speculating that there are more Defenders with drum handbrakes than X brakes and you dont hear of that many problems. slightly odd as if that were the case why would there have been a need for a disc handbrake? i didnt know the x brake had been out 40 years either otherwise that would be slightly unfair comparison. not sure where the dangerous bit comes from, as most would agree disc brakes are far better than drum brakes Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
15th Feb 2009 10:27am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
I think there have been some interesting comments by all.
I think, however, for everyone here who has heard of a drum brake failing there are many that havent. None of mine has. And drum brakes remember have been around for many years and still are. But then - here is an interesting comment: how many of you service and check your drum brake? either as part of the weekly/monthly checks or a service. It is part of the braking and drive line systems. If you neglect something its bound to develop issues! All the comments surrounding warranties and legal issues arent one to be repeated as we have all said, but removing the thought of rolling, just any general failure or issue attributed to that would land you in the stick - and it isnt hard. No amount of evidence of use or longevity or even the company is going to help if you are in the dock i said at the begining each to their own - there is still no way i would buy one, why mess with something that will work fine Mike |
15th Feb 2009 11:42am |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
Mike
I think your last comment is the issue. I have had my hand brake back to the dealer so often it is ridiculous, they just don't seem to be adjust them to work when the drive train is hot and then subsequently when it cools off. The result is that the drum doesn't work. As to the comment earlier about LR not honouring the downstream components under warranty that is something I hadn't thought of, although they claim the load goes the other way, i.e. the load is on the transfer box when the brake binds, rather than the rear diffs. With this in mind I might stick with the standard until the end of three years and wave it goodbye on the anniversary. |
15th Feb 2009 12:01pm |
i agree as above, in my 'limited?' experience it doesn't work fine Cheers
15th Feb 2009 12:43pm |
Some people have problems with the brake drum - but not all and certainly on none of my other land rovers with drum brakes Mike |
15th Feb 2009 1:50pm |
The only reason we have a drum brake is down to cost and not wanting to change tooling etc disc brakes always work and are self adjusting and only need pads changing when worn out, remember all the grief adjusting drum brakes before we had discs
16th Feb 2009 12:21am |
Edd80Inch Member Since: 18 Oct 2008 Location: Devon Posts: 28 |
A bit late to this one but im with MSE. Most of the wheeled plant fleet we run, dumpers, JCB's etc have a disc transmission brake, In my opinion they are crap. I seem to spend forever cleaning and adjusting them, and even when new they dont work very well.
I have never had a problem with a well maintained drum parking brake on a Landie and I wouldnt trust a disc brake on my 90. Edd. 1999 90 TD5 County 1943 Ford GPW Jeep |
29th Mar 2009 10:16pm |
