Home > Maintenance & Modifications > Defender led lighting
Page 2 of 2 <12
Grockle
I think you'll find without drilling the body they won't fit in the head light surrond. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #7276 14th Feb 2009 3:59pm
mse
You can get adaptors of ebay for that Mike
Post #7278 14th Feb 2009 5:25pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
what do you mean by "headlight surround"? these are for the rear.
Post #7286 14th Feb 2009 7:57pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
nicks wrote:
you can drill new holes, but i'm going to re drill the plinths to use the existing holes.
That sounds like a much better idea. I assumed looking at the pic's that the plinths had two screw holes internal to the light mounts that you used but wasn't sure. I've been told to fit NAS light units required new holes, but that was for the standard bulb type ones.
I assume you mean the plastic panel around the headlights. The holes for the lamps are the same measurements front or rear of the vehicle. I take it you mean it won't clear the actual outer ridge on the plastic panel. That's worth noting but as mentioned these are for the rear. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #7288 14th Feb 2009 8:57pm
werdan
Australia 2003 Defender 110 Td5 SW Bonatti Grey
Has anyone tried something like these?
http://www.ledshoponline.com/automotive_leds1156.htm
I like the idea of using LEDs but I prefer the classic shape of the 'dalek eyes' compared to the NAS lights.
My main concern is I'm not sure how waterproof these types of units would be.
Post #7291 15th Feb 2009 12:54am
dm_td5
Andrew, the lenses and back are a single fused piece so the only point for water to come in is through the socket on the rear which has a foam gasket. Regardless of the bulb you use. I haven't had a problem with water entry or condensation in either my Tdi or Puma's lamps and that's with the high humidity up here. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #7292 15th Feb 2009 3:51am
werdan
Thanks Derek!
Post #7293 15th Feb 2009 4:31am
Page 2 of 2 <12
