Home > Maintenance & Modifications > Lower grill woes |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
You’ll need to drill out the rivets from the outside and either bolt or rivet the new one in. 2007 110 TDCi Station Wagon XS
9th Sep 2018 7:59am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7904 |
As above, it is easy even I managed to do it! Good luck and photos please James
9th Sep 2018 8:01am |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 |
Thank you for the prompt replies. Never drilled rivets but will give it a go!
9th Sep 2018 8:09am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
Use a new drill bit slightly smaller than the rivet head. It should fit nicely in the rivet "hollow". Go slowly/carefully with the back of the grill properly supported. Not too much pressure, let the drill do the work.
All being well the head of the rivet will come off and you should be able to push the remains through the hole. It is always worth practising on a rivet in some scrap metal if you can,before you go for the real thing. Not a difficult job. |
9th Sep 2018 9:11am |
You might also find it easier to take the whole grill surround off (screw across the top and one large screw on each side). Then you can drill them out in full view wherever easiest. James
9th Sep 2018 5:09pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
As James says, take the whole grille off to make life easier. It's much easier to fix the new grille with machine screws and nuts rather than pop rivets an. of course much easier if you have to take it off in the future,
Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
10th Sep 2018 7:58am |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 374 |
LR just painted the grille for me as part of my purchase. Was this silver or body colour from factory?
10th Sep 2018 8:27am |
No it's a stainless steel one from Nakatanenga. Defender 90XS SW
10th Sep 2018 8:37am |
From the LR factory?
10th Sep 2018 8:43am |
No, from 4x4 Overlander. Defender 90XS SW
10th Sep 2018 8:45am |
Ok sorry, to clarify, what I was asking, this grille is a painted section from the factory?
Mine was standard and in a right state (2013 car), it was as if the factory had painted the stainless and it had reacted. |
10th Sep 2018 9:04am |
From the factory, it's a silvery colour. I'm not sure what the coating is but it's rubbish and corrodes as soon as you look at it. Darren
10th Sep 2018 9:05am |
Ok, well mine is now body coloured so lets see how long that lasts!!
10th Sep 2018 9:26am |
It's very cheap Aluminium not stainless, that's why it doesn't last long, it corrodes and forces the paint off. mine was body colour originally. |
10th Sep 2018 9:42am |
