Home > Puma (Tdci) > Clutch issues
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Clutch issues
I'm sure many of you are aware of the issues with the OEM clutch being made out of chinesium and dropping springs/rattling etc. I replaced mine on my driveway with a Clutchfix kit and all has been well for a year now.
Unfortunately I've been experiencing the dreaded rattle again and got in touch with Ben (Williams I think it is) to let them know as the years warranty was within a few days of expiring. Turns out they've had a few issues with a batch of clutch plates with insufficiently preloaded springs meaning that the death rattle will reoccur.
They've been a good as I would expect. No quibbles about, what they're saying is, purely a cosmetic issue and are sending out a replacement kit ASAP. Of course this does mean the gearbox is coming out again!
For anyone who is experiencing similar issues, give them a call or message 👍
On a side note, has anyone got a transmission jack or engine hoist/crane they can do without for a week? Rolling Eyes
Post #726467 31st Aug 2018 3:45pm
familymad
Well impressed you are doing that on your drive. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #726493 31st Aug 2018 5:48pm
BenB8man
I have to admit, I started to regret it when I got to this stage..
Post #726500 31st Aug 2018 6:20pm
It really is much easier if you remove the transfer box first, then the main gearbox. Both parts are nearly manageable then, plus you can inspect and grease the infamous adaptor shaft.
You've done well to get it out as a single lump using only hillbilly tools!
What's happened to your gearbox breather?
Post #726504 31st Aug 2018 6:54pm
BenB8man
Hillbilly? Pah! How dare you! Laughing
Honestly though, I think I will get a proper crane/transmission jack for this job. It was a pain the first time.
Last time it was out I did the Ashcroft conversion. I might split them and have a little look to see if it's working as it should.
The breather no longer vents into the bell house. It's redirected to a manifold that connects the diffs and transfer box breathers and vents at RAI height. Think I might tap it this time it's out and put a quick connect on it though.
Post #726514 31st Aug 2018 7:53pm
Aha, both good mods. It'd be interesting to know how the AT shaft is looking, hopefully clean and oily.
If you remove the gearbox breather fitting to tap it you may find (as I did) that it is extraordinarily difficult to screw back in because it is such a fine thread and so hard to align.
A gearbox jack is one of those tools that when you get one you wonder how you ever managed without!
Post #726556 31st Aug 2018 10:30pm
