![]() | Home > Td5 > TD5 Non Start |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Tried the inertia switch? Instagram @defender_ventures
Empire Tuning - Agent |
Td5Cam Member Since: 09 Apr 2016 Location: Somerset Posts: 32 ![]() |
I havent no, do i need to just press the switch or check the current through it?
Just push it down. Should be it Instagram @defender_ventures
Will give it a try tomorrow, thanks
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 ![]() ![]() ![]() |
When you say it won’t start, you mean it won’t fire or the engine doesn’t even turn over?
You say you replaced the starter motor, new? The solenoid is operating correctly? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Sounds like a bad gearbox or transfer box earth to me. I'd be checking all earths and battery connections
![]() Definately try the inertia switch too as above ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Doesnt turn over, as if there is no power, but there is as there is as have checked the voltage and current from the ignition switch right through to the starter and there is a cirrent going right through.
When i turn key to point II on the switch the dash doesnt bring up any of the normal warning lights e.g. battery, oil etc, i just have the amber coil light and eml and a fog warning light, turn the key further and there is just nothing, i can hear the starter relay click and as said above i know its putting current across the circuit. Have checked the earth and nothing seems to be lose or corroded and the connections at the battery appear in good order. Brand new starter and brand new battery. |
I'd definately be checking earths straps.... 2002 90 Td5 Station Wagon
Ok will give them another look over once checked inertia switch.
When the inertia switch is tripped, generally, you don't get glow plug or MIL. 2002 90 Td5 Station Wagon
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Inertia switch does not stop the engine turning over on the starter motor. 02' 110 TD5 Double Cab Rebuild Thread
Can rule out inertia switch, just checked that.
Will give the earth straps another check and clean them up. If this fails are there any other thoughts? |
With ignition at position II is main relay and fuel pump relay operating can you hear the fuel pump
![]() Click image to enlarge 1999 to 2001 relay https://1drv.ms/w/s!AtZSoWFHDgnGhQzNRkjTwxAH0liJ Last edited by dorsetsmith on 29th Aug 2018 3:32pm. Edited 7 times in total |
No cant hear fuel pump.
