Home > Maintenance & Modifications > Self-tapping screws - hole too big
jimmythomson
I've just started replacing a few lights on my '96 110, and on a few of them the holes for the self-tapping screws have been worn to the point where the screw no longer holds the light. What are my options here? None of the ideas I have in my head are ideal:
1) Rotate the light and form new holes
2) Add a bit of metal the other side of the hole for the screw to bite in to
3) Use a stainless bolt/nut alternative to the self-tapping screw (if I can find the right size and head)
I'm guessing option 1 is the most common. Thought I'd see if anyone's got any other options or opinions.
Thanks,
Jimmy.
Post #725832 28th Aug 2018 4:15pm
zsd-puma
Which lights?
If you mean the round ones (indicators, brake, side lights etc) then they either had a plastic plug (fits in a square hole) which the screws went into, like a rawlplug.
Or the earlier ones had a small captive spire nut clipped over the panel hole and the screws went into these - these often rust and fall off when you remove old screws.
I'm not sure when Rover changed the fixing method.
Post #725836 28th Aug 2018 4:21pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Spire clips may help
https://www.ebay.co.uk/i/192586749514?chn=ps&var=492746282041 Thumbs Up
(zsd-puma beat me to it)!
Post #725837 28th Aug 2018 4:21pm
jimmythomson
Sorry, should have said that I'm referring to the round lights. See below:
A photo to show the context:
The screw here just passed straight through the hole without much effort:
I suspect those U nuts may well be what I need.
Thanks,
Jimmy.
Post #725841 28th Aug 2018 4:29pm
zsd-puma
it probably had the spire clips originally, but looks like it's been repaired/repainted at some point, they probably got lost/disintegrated when that was done.
Post #725847 28th Aug 2018 4:39pm
dorsetsmith
https://www.landroverworkshop.com/diagrams...or_52867#6
AK606021L - SPRING NUT U TYPE - DEFENDER
Post #725848 28th Aug 2018 4:41pm
jimmythomson
Brilliant! Thanks very much. I'll get some of those ordered.
Jimmy.
Post #725849 28th Aug 2018 4:46pm
jimmythomson
Another quick light related question. This time it's the side repeaters. I should probably mention that I'm fitting this kit: eBay Item No. 361934176052
The connection for the side repeaters just doesn't feel tight. Has anyone fitted this kit from 'boltonbits'? The connection goes in as you can see from the photo, but I don't think it'll be too long before it's working itself lose. Am I missing a trick? Should I just wrap it in electrical tape? Photos for reference....
Post #725857 28th Aug 2018 5:13pm
shropshiredefender
Self amalgamating tape is your friend here Thumbs Up
Post #725858 28th Aug 2018 5:24pm
zsd-puma
Either self amalgamating tape;
https://www.screwfix.com/p/self-amalgamati...tid=416546
Or you can get heat shrink that'll fit over it.
Post #725859 28th Aug 2018 5:26pm
jimmythomson
Thanks, guys. I've got some of that on order from Screwfix. Will pick up tomorrow and crack on Thumbs Up
Post #725860 28th Aug 2018 5:29pm
mk1collector
The hole in your wing looks the wrong shape for those side repeaters Ray
My build thread
Post #725875 28th Aug 2018 6:34pm
jimmythomson
Ray - I thought so too when I first saw them, but they're designed to fit as per the smaller original rectangular ones. I haven't actually put them in yet, but they look like they're going to be okay from a visual inspection.
Post #725877 28th Aug 2018 6:41pm
jimmythomson
Ray - just checked and they fit in nicely. Thumbs Up
Post #725882 28th Aug 2018 7:04pm
mk1collector
Excellent Thumbs Up didn’t know anyone made them for the smaller hole. Ray
My build thread
Post #725889 28th Aug 2018 7:25pm
