Home > Maintenance & Modifications > Self-tapping screws - hole too big |
Which lights?
If you mean the round ones (indicators, brake, side lights etc) then they either had a plastic plug (fits in a square hole) which the screws went into, like a rawlplug. Or the earlier ones had a small captive spire nut clipped over the panel hole and the screws went into these - these often rust and fall off when you remove old screws. I'm not sure when Rover changed the fixing method. |
28th Aug 2018 4:21pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Spire clips may help
https://www.ebay.co.uk/i/192586749514?chn=ps&var=492746282041 (zsd-puma beat me to it)! |
jimmythomson Member Since: 18 Jul 2017 Location: Norfolk, UK Posts: 46 |
Sorry, should have said that I'm referring to the round lights. See below:
A photo to show the context: Click image to enlarge The screw here just passed straight through the hole without much effort: Click image to enlarge I suspect those U nuts may well be what I need. Thanks, Jimmy. |
28th Aug 2018 4:29pm |
it probably had the spire clips originally, but looks like it's been repaired/repainted at some point, they probably got lost/disintegrated when that was done.
28th Aug 2018 4:39pm |
https://www.landroverworkshop.com/diagrams...or_52867#6
AK606021L - SPRING NUT U TYPE - DEFENDER |
28th Aug 2018 4:41pm |
Brilliant! Thanks very much. I'll get some of those ordered.
Jimmy. |
28th Aug 2018 4:46pm |
Another quick light related question. This time it's the side repeaters. I should probably mention that I'm fitting this kit: eBay Item No. 361934176052
The connection for the side repeaters just doesn't feel tight. Has anyone fitted this kit from 'boltonbits'? The connection goes in as you can see from the photo, but I don't think it'll be too long before it's working itself lose. Am I missing a trick? Should I just wrap it in electrical tape? Photos for reference.... Click image to enlarge Click image to enlarge Click image to enlarge |
28th Aug 2018 5:13pm |
Self amalgamating tape is your friend here
28th Aug 2018 5:24pm |
Either self amalgamating tape;
https://www.screwfix.com/p/self-amalgamati...tid=416546 Or you can get heat shrink that'll fit over it. |
28th Aug 2018 5:26pm |
Thanks, guys. I've got some of that on order from Screwfix. Will pick up tomorrow and crack on
28th Aug 2018 5:29pm |
The hole in your wing looks the wrong shape for those side repeaters Ray
28th Aug 2018 6:34pm |
Ray - I thought so too when I first saw them, but they're designed to fit as per the smaller original rectangular ones. I haven't actually put them in yet, but they look like they're going to be okay from a visual inspection.
28th Aug 2018 6:41pm |
Ray - just checked and they fit in nicely.
28th Aug 2018 7:04pm |
Excellent didn’t know anyone made them for the smaller hole. Ray
28th Aug 2018 7:25pm |
