Home > Other Site Sponsors > Futuranet Puma Gauges Controller
Martin
Site Admin
Previous post including videos: http://www.defender2.net/forum/post707908.html#707908 (videos also below)
I'm happy to announce these officially and make them available!
LR Def Puma Dash Gauges Controller
https://www.fnltd.co.uk/shop/puma-gauges-c...r-p87.html
Nothing like a snappy title, and that's nothing like one!
This controller converts the hard-wired signals present on pre-Puma Defenders into the CAN bus messages and control signals needed to correctly and fully operate the Puma (Tdci) Defender’s gauge cluster – whether installed as part of an entire Puma dashboard or a custom build with just the gauges.
As an add-on to the controller are two types of adapter looms, depending on the currently installed gauges. The adapter loom allows the installation of all the wiring for the gauges to be plug-and-play for a Td5, and reduces the wiring needed for earlier vehicles to an absolute minimum.
For hard-wiring, building your own loom or if you have a custom loom you can buy a connector pack or individual connectors as you need.
Supported by the controller now are the following engines/ECUs: Td5, Motronic V8, 14CUX V8, GEMS V8, 300 Tdi, 200 Tdi. Any engine can be accomodated and we have a full database of LR temperature sensors. If you have an engine or installation that is currently unsupported we do have the ability to customise a controller for you so please contact us.
Controller: £285 inc VAT (£237.50+VAT)
Td5 Plug-and-Play Loom or non-Td5 adapter Loom: £80 inc VAT (£66.67+VAT)
https://www.fnltd.co.uk/shop/puma-gauges-controller-p87.html
Start Up Video
Drive Video
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #716957 9th Jul 2018 9:53pm
iceshj
Hi, can I order controller & loom for my 300tdi (without Ecu)
Thank you
Regards
Dave Very Happy Defender 90 softop (in bits)
Range Rover Hybrid SVAutobiography
Discovery 3 HSE
Kawasaki ZX12R
Post #716975 10th Jul 2018 5:59am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Great job Martin Thumbs Up
few Q's:
Will you be able to use the kit with a speedo healer for use with non-standard ratio diffs?
Also do you have a list of warning lights that are in the tdci unit? Are they all the same as td5?
Can you supply the controller and the Tdci dash gauges??
Post #716980 10th Jul 2018 7:10am
Martin
Site Admin
Dave I'll send you the link once it's online Thumbs Up
Matt: no issue to use a speedo healer (I assume you are doing this before the Td5 speedo?) - it's only where you have it wired in which might affect the ability to use the plug-and-play loom.
I was not planning on supplying the Puma gauges but if you are having trouble sourcing a set then I'm sure I can help.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #717012 10th Jul 2018 12:21pm
Defendermatt
I have looked for a set of puma clocks and not much comes up at a sensible price point, especially when compared to the discovery 3 or freelander unit.
If you could help sourcing that would be cool.
Matt
Post #717015 10th Jul 2018 12:45pm
Martin
Site Admin
They are definitely rarer than and so command a premium over the D3/Fl2 gauges - which can't be used for this conversion.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #717022 10th Jul 2018 1:16pm
Martin
Site Admin
Hi all,
Online shop link finally live. Although I thought I had the various options down to a minimum it's still been a mission to get it all set up on the shop!
Any questions just ask Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #717033 10th Jul 2018 3:25pm
Martin
Site Admin
If you need a different loom or adapter than what is currently on offer do let me know. I've made some assumptions as to what people might need but obviously every installation will be different Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #717163 11th Jul 2018 1:43pm
Martin
Site Admin
Absolutely delighted to say that the first batch of controllers have gone out to their new owners today Mr. Green
Very proud to be supporting UK manufacturing - the controller board has been made in the UK and we assemble the controllers up and make all the looms ourselves in Oxfordshire Cool
2015 D90 XS SW
Post #725066 23rd Aug 2018 5:09pm
ibexman
Well done Martin I’m waiting for the holy grail Thumbs Up
Post #725076 23rd Aug 2018 5:39pm
sloderby1
Just out of interest, does this work with clusters from 2.2, 2.4 or both?
My understanding was that the CAN messages are significantly different between 2.2 & 2.4.
Post #725257 24th Aug 2018 4:01pm
Martin
Site Admin
Hi, sorry I totally missed this question over the BH weekend.
The controller supports gauges from both 2.4 and 2.2 Defenders Cool  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #726061 29th Aug 2018 1:06pm
Good work Martin Thumbs Up
Post #726172 29th Aug 2018 7:40pm
Martin
Site Admin
Bump as it's been a while since I've mentioned these Whistle
Now supporting a wider range of engines including Rover V8s with either carbs or 14CUX/GEMS/Motronic engine management.
I've also done a calibration sweep on pretty much every known LR coolant temperature sensor so if you know the sensor fitted the controller can read it Smile
If you're thinking of a Puma dash installation or an engine swap into your Puma then give me a shout Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #738409 3rd Nov 2018 2:44pm
Mr.J
United States 1987 Defender 90 2.5 TD HT Willow Green
This is amazing work!
I currently own a 90 with a junky 19J, will be swapping to a 200tdi and a Puma body. Seems like you have a solution for the cluster. Will be ordering shortly.
Post #851052 20th Aug 2020 3:05am
