Home > My Defender > Project Defender
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Project Defender
Started getting a decent amount of work done on my Defender, couple of people I've been speaking to suggested starting a blog to write about what I do. If your interested, check it out. Only got my second post on it, but hpping to get some good information on there. And constructive comments more than welcome guys! Thumbs Up
http://hobbs92.blogspot.com/ Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #72403 23rd May 2011 11:19pm
toshers
Scotland 2011 Defender 110 Puma 2.4 USW Orkney Grey
I note from your blog you work in the Inverurie branch of Halfrauds...been in there quite a lot but I haven't seen the truck parked outside?!?
If I see it I'll pop in and say hi.
Good work on the blog, keep it up!
Post #72430 24th May 2011 7:26am
Zagato
Great Blog Ben, good luck with it Thumbs Up
Post #72431 24th May 2011 7:31am
110SEB
Ben, excellent job. Itll be an interesting and useful reference as it goes along.
What do you use to publish your blog? I have had a go with the Google thing but it looks ****.
Keep it up! (The blogging that is Embarassed Rolling Eyes )
Post #72440 24th May 2011 9:04am
Maverick
Cheers guy, did hope it would be a good reference! Thumbs Up
Its Hellfrauds, actually! Laughing
I'm usually in Saturdays, but sounds like I'm going to get a lot more hours over the summer. You'll usually find me in the tool box in the bike hut! hahaha Ben
Post #72477 24th May 2011 12:26pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Good job mate Thumbs Up
Stick the blog link in your sig and then that will act as a reminder for us to check back when you post Jon - 110 td5 [sold]. Currently Defenderless.
Post #72481 24th May 2011 12:40pm
Maverick
Good plan Batman! Thumbs Up Ben
Post #72488 24th May 2011 1:00pm
Maverick
Hi all,
Long time no see! Totally forgot about the blog idea, what with uni I've not had much time to write about updates. Took the Defender off the road in July after finally getting a galvanized chassis. Got a Disco 1 300TDi for a run around (bad idea, nothing but trouble) with the plan to break it and use parts on the Defender (did someone say transfer box?). Got the beast back on the road on Thursday, must say I'm very pleased! Shall eventually get round to updating this with a build thread but a bit short of time for that at the moment, plus a bit hard to type past the perma-grin. Mr. Green So, here's a few before shots, and the only after shot I have ATM.
Shot from Banff, with a local car forum
Spot of off-roading
Before I got the spanners out
Taken today, just after I parked up for uni. Ignore the red doors, ordered some fibreglass doors ones, got them all painted up to find out that a recess was missing, so the window won't fit when they're down. Should be back here by the end of this week, so can build them up and fit them.
And here's the Disco on one of it's 'little disputes'! Decided it doesn't need an oil cooler Rolling Eyes
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Ben
Post #189110 27th Nov 2012 10:51pm
Maverick
Copying what I've written on another forum
Stripped out the interior, all that's left is the dash. Wiring all over the place till I get the dash out. Pictures say more than words really...
Who sunk the Defender?
All the doors off now too. Need to get the wings and rear tub off, and sort the wiring at the back.
Finally, here's the new chassis. Rubbish picture because I popped home on my lunch break from work on Friday to have a look.
Post #189114 27th Nov 2012 10:59pm
Maverick
Only a few hours after dinner and spent them trying to get wings off. Left hand one is off, most of the right hand one has been unbolted too. Quite an annoying job, especially when trying to find bolts under layers and layers of mud! Car now looks like this
Want to try get the other wing off and the tub off by the weekend. Looking at the bulkhead more and more of it is looking shot! Worst job still have to be the wiring, no plugs just bullet connectors!
Tub came off without too much difficultly, with a bit of help from my new favourite tool the angle grinder Thumbs Up Unfortunately, the tub isn't in great condition, galvanic corrosion around almost every mounting point, and the seat base is beyond economical repair in my eyes.
Rear tub mounts
Corrosion around fuel filler
And the other side, behind drivers seat
Seat base mount
Seat belt and chassis mount
Using aluminium plate, sealant, glue and rivets we carried out some repairs.
Rear tub mount
Seat base mount, seat belt mount and chassis mount
Post #189115 27th Nov 2012 11:02pm
Maverick
Once the tub off, it was time to get the bulkhead off. Ground through the mounting bolts, and hammered it backwards off the bolts it eventually came free. As this is steel, and poorly painted it was in very poor condition, can fix it with weld but to save time we bought another one that needs slight modification instead of major welding. Next out was the prop shafts and gearbox...
Back off the engine with clutch in place
Removed the clutch and you can see a little damage to flywheel bolts from where the clutch plate was put in the wrong way round (not me I will just add)
Took the started motor off, inspected and there is slight damage to the gear. It would appear that the motor isn't disengaging properly. Could possibly need a new ring gear on the flywheel
Took the bell housing off the gearbox, going to clean it and the gearbox ready for reassemble.
Rear hub was removed earlier this week, replaced the bearing to find that that are slightly too small for the stub axle, so shall be on the hunt for some bearings as soon as possible
My main job today was to remove the inlet and exhaust manifold and clean the head and block.
WD-40 on the head and it comes up beautifully.
Using Gunk degreaser on the block and then some WD just to finish it off.
Also got the A-frame off today, bit of persuasion with the breaker bar and it came off relatively easy.
Ball joint mount on the axle also off reasonably easily too
Post #189116 27th Nov 2012 11:03pm
Maverick
Removed the axle from the old chassis. Taken both the hubs off too
Wire brushed and painted
Hub rebuilding
And finished :biggrin:
Axle now sat back on the old chassis, so I can move it back in the chassis.
Also got the new chassis painted, not to make it look good but, to stop people stealing the car! Galvo chassis is a big attraction when it comes to a defender, and don't want mine to be a target!
First used a mordant solution on the chassis, washed down and let that dry. Then on with the acid etch, two coats (with some help from Fletty)!
After the primer was dry, couple of coats of Jotun Conceal (marine grade paint) and looking good if I do say so myself!
Also cleaned up a few brackets and painted them too
Now waiting for a chance to clear up the garage, roll the chassis in and get ready for engine removal :thumbsup:
Post #189117 27th Nov 2012 11:05pm
Maverick
Guess what's missing! Thumbs Up
One engine!
Very happy with that!
Got both the axles off, cleaned and painted. Along with Radius Arms, Panhard Rod and so on.
One clean axle
Chassis ready for rear axle
And on...
And front axle on too
Hell of a days work
Shall hopefully have engine and fuel tank in tomorrow and get the oil seal sorted. Then onto gearbox and prop shafts! :smile:
Post #189118 27th Nov 2012 11:07pm
Maverick
As a bonus...
Engines in!
Flywheel off and cleaning up waiting for a new oil seal
That was back in September, and the last update I had a chance to write. Shall slowly finish off the build thread over the coming weeks.
Post #189119 27th Nov 2012 11:09pm
Killer90
Site Sponsor
Shocked good job mate, alot of pieces to go Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #189122 27th Nov 2012 11:49pm
