Home > Puma (Tdci) > clutch rattle
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
clutch rattle
hi got a 26k mile 2011 defender 110 xs has a rattle on clutch that goes away when clutch is depressed, i am thinking its the dreaded springs, its mainly used for towing a caravan and camping.
Looking for recommendations for hd clutch and slave fit and if to fit an Ashcroft or greased land rover oem input shaft i am on derby notts border but prepared to travel for a proper job!
dean 07904021190
Post #723468 14th Aug 2018 5:32pm
Dean Watson
thanks for all the help!
Post #723645 15th Aug 2018 7:06pm
Caterham
Rolling with laughter
I think I sent you PM......I see no one else has bothered to help.
Post #723646 15th Aug 2018 7:15pm
zsd-puma
Well ok, you said you were prepared to travel. I got my done by Derek Linch haulage in Kent..... Laughing
Post #723649 15th Aug 2018 7:18pm
MK
For the clutch, probably clutchfix or from the transit 4x4; the latter probably being a bit noisier at idle as does not have the central dampering hub. Look for dgardel forum member's advice for the transit clutch.
I would go for the ashcroft output kit if I would live in the uk. I'm actually sourcing a local solution for my output shaft. Puma 110" SW
Post #723651 15th Aug 2018 7:24pm
leeds
Go for a Clutchfix. Now since yours is a 2011 Defender the chances are you have not got the uprated slave cylinder so will need the valve and adaptor. Available HERE
Brendan
Post #723693 15th Aug 2018 10:07pm
MK
What is wrong (now!) with the std slave cylinder? Puma 110" SW
Post #723695 15th Aug 2018 10:41pm
Dean Watson
hi thanks for the replies , got the Pm from Wayne thanks for that , just looking now for recommendations for someone to fit the parts.
Post #723724 16th Aug 2018 7:29am
leeds
The exact reason why LR did an uprated clutch I am unsure about. Apparently latest clutch slave cylinder gives a lighter pedal.
Think the VIN number fiited from is VIN FA459934 however I need to verify that.
Brendan.
Post #723729 16th Aug 2018 7:57am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Nothing wrong with it but Brendan is right you do need to change it for the new type as I don't think you can actually buy the old type any more - and you'd be silly not to change it whilst you're in there! Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #723733 16th Aug 2018 8:13am
zsd-puma
The new type supposedly give a lighter pedal feel I think, though the difference is marginal.
Post #723734 16th Aug 2018 8:17am
