- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Rear springs for 110 200tdi |
Jim_m_kidd
Rear springs for 110 200tdi | |
Hi - I am doing a bit of a suspension refresh on my 1992 110 200tdi Hardtop (that's now a ragtop).
I have so far decided on original spec springs at the front (NRC8044 & 45) and I have already selected Bilstein shocks all round.
What I was also thinking is the standard rears springs are NRC6904 and NRC 6389 - reading about these they are "HD" as standard verses the front - so have a spring rate of 330lbs (as opposed to 155/215 on the front).
Now my 110 is only ever lightly loaded and now has no rear weight and the roof is gone and I find the ride ever so slighty 'crashey' from the rear.
My thinking is that the spring rbk101111 which I think are those fitted to later 110's might be a fit as they are progressive 270 > 420lb. So in principle they'll be slightly more compliant and give me the better ride.
So my questions
Will the rbk101111 spring fit on my early 110?
Anybody done this before?
Jim
10th Aug 2018 8:31am |
dailysleaze
rbk101111 will fit but they'll be harsh. I have them on my mostly unloaded SW and they're too uncomfortable. I'll likely go to the green/green/white at some point. When you have 800kg of sand in the back though they're beautiful
11th Aug 2018 7:27am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
