Home > For Sale & Wanted > [Wanted] Td5 inward-facing seats lap-belt bolt
Green Machine
This is a long shot, but don't suppose anyone has a spare lap-belt kicking around that has the fixing bolts on it? I've lost one. It's the type with a fat collar immediately under the bolt head and then a similar chunky washer on the other side of the seatbelt bracket. Also has some sprung retainer plates on the bolt.
I just need one bolt, but would buy a whole lap belt or one end of a lap belt of somebody to get the bolt if preferred. A new buckle end is £40, which makes it rather an expensive bolt!
Thanks. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #721587 5th Aug 2018 5:03pm
I've got some old seatbelts in the garage, might be one of those. Have you got any dimensions that I can compare to?
Post #721609 5th Aug 2018 8:54pm
Green Machine
Thanks Jim. Thread is a little bigger than M10 (assume imperial), but take a 17mm socket. About 40mm thread length. The distinctive thing is the collar under the head, which is about 2mm thick and then there’s a spacer washer that’s also about 2mm thick. I think they’re used on all the lap belts (including middle seats) and possibly on the 3-point belts in the middle row, though not certain on that.
Cheers. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #721616 5th Aug 2018 9:34pm
Seat belt bolts are typically 9/16 UNF. Darren
Post #721637 6th Aug 2018 7:37am
Sorry for the delay.....
This type?
I've got a few here. PM me your address and I'll chuck them in the post
Post #722447 9th Aug 2018 7:43am
Green Machine
Thanks a lot Jim, I think that is the correct type (at work so don't have reference, but it looks right).
Have sent you a PM. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #722497 9th Aug 2018 12:36pm
