![]() | Home > For Sale & Wanted > [Wanted] Td5 inward-facing seats lap-belt bolt |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
I've got some old seatbelts in the garage, might be one of those. Have you got any dimensions that I can compare to?
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Thanks Jim. Thread is a little bigger than M10 (assume imperial), but take a 17mm socket. About 40mm thread length. The distinctive thing is the collar under the head, which is about 2mm thick and then there’s a spacer washer that’s also about 2mm thick. I think they’re used on all the lap belts (including middle seats) and possibly on the 3-point belts in the middle row, though not certain on that.
Cheers. 2005 Td5 | 90 Station Wagon | Tonga Green |
Seat belt bolts are typically 9/16 UNF. Darren
Sorry for the delay.....
This type? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I've got a few here. PM me your address and I'll chuck them in the post |
Thanks a lot Jim, I think that is the correct type (at work so don't have reference, but it looks right).
Have sent you a PM. ![]() |
