![]() | Home > For Sale & Wanted > [Wanted] Far Corners Cluster Bar |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 838 ![]() ![]() |
Not got one but seen this that’s similar and cheaper depending what you want to do with it
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4251 ![]() ![]() ![]() |
That’s what I have already and I’m not happy with it. I didn’t want it as per that photo, as you have to cut the grill surround and it looks a bit odd to me with spots hanging down. Instead I mounted it lower down through the grille bolted onto the frame of the ac condenser. I could then put the spots on top. There are a couple of issues with that. It was so awkward to mount I ended up with a really convoluted bracket that moves with vibration when off road so it end up at a slight angle every few thousand miles. It’s quite a bit of weight on the condenser frame as well and I’m having a new one of those so was looking for a neater alternative.
![]() Click image to enlarge 2007 110 TDCi Station Wagon XS |
Ah got you now.
I’m looking at fabbing something up top take a light bar on the front with a similar mounting on to the grill mounts but with a flat bar between. I’ve got the flat metal wolf grill fitted so I don’t have to chop the plastic one. A laser lamp grill would look good but they are big £ |
I just can’t find exactly what I’m looking for, hence why I keep buying things and not fitting them as intended. 2007 110 TDCi Station Wagon XS
