Home > For Sale & Wanted > [Wanted] Far Corners Cluster Bar
Bluest
A long shot, but does anyone have a Far Corners Cluster Bar they might want to sell? I want to modify it very slightly and even then I'm not sure I'll like it, so would prefer used over new.
One of these:
 2007 110 TDCi Station Wagon XS
Post #721237 3rd Aug 2018 2:32pm
Bps
Not got one but seen this that’s similar and cheaper depending what you want to do with it
Post #721294 3rd Aug 2018 6:44pm
Bluest
That’s what I have already and I’m not happy with it. I didn’t want it as per that photo, as you have to cut the grill surround and it looks a bit odd to me with spots hanging down. Instead I mounted it lower down through the grille bolted onto the frame of the ac condenser. I could then put the spots on top. There are a couple of issues with that. It was so awkward to mount I ended up with a really convoluted bracket that moves with vibration when off road so it end up at a slight angle every few thousand miles. It’s quite a bit of weight on the condenser frame as well and I’m having a new one of those so was looking for a neater alternative.
Post #721303 3rd Aug 2018 7:01pm
Bps
Ah got you now.
I’m looking at fabbing something up top take a light bar on the front with a similar mounting on to the grill mounts but with a flat bar between. I’ve got the flat metal wolf grill fitted so I don’t have to chop the plastic one.
A laser lamp grill would look good but they are big £
Post #721305 3rd Aug 2018 7:11pm
Bluest
I just can’t find exactly what I’m looking for, hence why I keep buying things and not fitting them as intended. 2007 110 TDCi Station Wagon XS
Post #721310 3rd Aug 2018 7:38pm
