Home > Maintenance & Modifications > Sagging Door Seal
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Sagging Door Seal
Recently pulled drivers door seal from its door frame to access the side of roof-lining. Since pushing it back into place it occasionally sags and comes away from frame. Is there a good way of securing it to the frame to prevent sagging that allows for it to be removed as/when needed in future? (I would prefer not to use glue) Bow down Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721045 2nd Aug 2018 1:11pm
ericvv
Post #721051 2nd Aug 2018 1:35pm
ericvv
Post #721053 2nd Aug 2018 1:38pm
zsd-puma
Try pulling it off again and squashing the u channel part of it tighter together, then push it back on again.
Post #721058 2nd Aug 2018 2:09pm
ChrisDefender
+1 above!
I had the same issue, took it off, squeezed it tightly together and pushed it on and its never moved since - brilliant! Very Happy
Post #721109 2nd Aug 2018 6:19pm
Sammyboy
Thanks guys, great advice. Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #721115 2nd Aug 2018 6:40pm
