Home > Td5 > Fitting a transfer box soon, plug needed
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi, I'm fitting a Disco Transfer box to my TD5 90 2001 soon. As the replacement box only has a diff lock switch and no hi/low switch I would have liked to run a cable from the plug that currently is connected to the old box and run it back inside the cab to a manual switch so if I need to I can manually flick it so the ECU knows whats going on. Yes, I could just chop into the loom but would rather not.
What I would like to know is the type of plug/socket I need to buy to accomplish this task and where I could get it from.
Thanks in advance Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #720589 31st Jul 2018 3:10am
PaulMc
C0685 is a Sumitomo HW series 3-way female connector -
I can supply the mating male connector for it Thumbs Up
. Paul.
Post #720762 31st Jul 2018 9:15pm
MC84
What would the cost be PaulMc? Mike
Ford 100e 1959
Post #720789 31st Jul 2018 11:48pm
PaulMc
£3.25 for the connector, supplied with 3 x terminals and wire seals, a blanking plug for cavity 2, and the secondary terminal lock.
1st class P&P will be £1.25 Paul.
Post #720849 1st Aug 2018 1:23pm
