![]() | Home > Td5 > Fitting a transfer box soon, plug needed |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Hi, I'm fitting a Disco Transfer box to my TD5 90 2001 soon. As the replacement box only has a diff lock switch and no hi/low switch I would have liked to run a cable from the plug that currently is connected to the old box and run it back inside the cab to a manual switch so if I need to I can manually flick it so the ECU knows whats going on. Yes, I could just chop into the loom but would rather not.
What I would like to know is the type of plug/socket I need to buy to accomplish this task and where I could get it from. Thanks in advance ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
C0685 is a Sumitomo HW series 3-way female connector -
![]() Click image to enlarge I can supply the mating male connector for it ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
What would the cost be PaulMc? Mike
