![]() | Home > Maintenance & Modifications > Arm rest/Seat hybrid??? |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
What if you put one of those under-cub by safes beneath the seat? Would raise the seat base to make a better arm-rest and give the dog a better view.
Get a bigger dog and lean on him?
Jez676 Member Since: 24 Feb 2013 Location: North Devon Posts: 178 ![]() ![]() ![]() |
Do the under cubby safes bolt to the centre seat box cover or to the middle seat mounting holes in the seat box frame?
I think I’m going to have to bespoke something. If it works I’ll post pictures if it doesn’t I shall pretend that this post never existed! ![]() |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 262 ![]() ![]() ![]() |
Hi Jez676
Is this what you are looking for ? ![]() Click image to enlarge |
Thank you for that.
If I had a platform that sat on top of that configuration that would work! Looks expensive though, who sells it? |
My cubby safe bolts to the same holes that the cubby uses. Must admit, I though they would be the same as those of the middle seat, but no idea if that is the case. |
Hi Jez676
The lid for the cubby box was a bought item and the armrests are from an old Discovery 2 fitted to the Defender seats and recovered to match. |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Def90
That sir looks great...well done ![]() Yours... ![]() Mine... ![]() I'm going to see how best to replicate the idea. Are the arms static? or do they lift with the lid? and it looks as though if the arms do raise they 'nest' nicely within the width of the two seats? anyway really nice solution...good to see another example in Defender land of an ingenious way to improve things... ![]() https://www.defender2.net/forum/topic83242.html |
Hi X4SKP
The armrests are fully adjustable and fold upright just like the Discover 2. They are a close fit with just about 5mm clearance to the cubby box lid but it opens and closes just fine. I was very pleased with the end result as they fit perfectly but you do need to care welding the armrest brackets onto the seat frames to get them perfectly aligned. It was a bit of tack welding fit and check a few times, I should have some photos of the seat frames and the brackets. |
Hello Def90
Thanks and understood. By chance I managed to source a pair of arm rests from a 2014 Disco' 3 that has be scrapped, now being stripped post accident damage. (£20 if I remove... ![]() So will be looking to get them recovered as they are currently... ![]() I'm also thinking about reversing the Lt/Rt Fit and making a bracket that extends from the Centre Cubby Box to mount these, and in doing so leave the seats as standard also allowing the tip forward (which I occasionally use to retrieve from directly behind the seats) without any potential issue. If this is a no go, when I've had a good look at this, I always have your route... ![]() 'Fat lid' also sourced matching my interior. Anyway a job for the Autum...'thanks... ![]() https://www.defender2.net/forum/topic83242.html |
Defensorprime Member Since: 22 Aug 2018 Location: SouthEast Posts: 8 ![]() ![]() ![]() |
Did OP ever get anywhere with this? I'm considering doing something similar in terms of a quick release seat base mounted Cubby box. I've been researching a lot to find a pre existing template for some inspiration!
ug2 Member Since: 01 May 2020 Location: Gloucestershire Posts: 23 ![]() ![]() ![]() |
This looks brilliant Def90! Could you give anymore details on how you did it? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Why would your dog want your knobs in his face?
Raise the cubby box with a sub enclosure beneath. Cubby now at correct height, and much better sounds. Dog on passenger heated seat. Dogs comfy, warm, you can dry seat, and dog gets his own window. Woman in the back, also you now can’t hear her due to improved sound system. Simples. |
