Home > Puma (Tdci) > Passenger power Window failure
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
I have a 2007MY Puma wagon.
The passenger side power window has stopped working. No noise, no movement. I checker the fuze - its ok. I changed out the up/down switch on the dashboard, I checked the wiring between chasis and door and di not find a break. I think it may be the regulator (motor) , what do you think?
Any issues with changing out regulator motor or is it faily straght forward?
Thanks guys.
Rob
Post #719397 24th Jul 2018 9:22am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Put a live feed direct to the motor, it will confirm if it’s the motor or the loom,
99% of the time it’s the door loom that’s at fault.
Did you test the loom, or just visually look at it? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #719400 24th Jul 2018 9:27am
zsd-puma
As cars go stripping the door down on a Defender is one of the simplest. It's worth buying the foam water shedder for inside the door, they're cheap from Land Rover. It's much easier than trying to salvage the old water shedder and adhesive.
And a trim removal tool for the door card clips will greatly reduce the chances of damaging the door card.
Post #719401 24th Jul 2018 9:28am
expatRob
No sir, I did not test the Loom, I do not know how to do that. I have a good tester can you tell me how to test it?
Also how do I put a "Live feed" to the motor?
I appreciate your guidance, I am new and learning.
Post #719404 24th Jul 2018 9:58am
zsd-puma
Strip the door down, unplug the motor, then connect the motor directly to a battery with a couple of bits of wire. If the motor works, you know it's the switch or wiring harness at fault.
Post #719406 24th Jul 2018 10:02am
expatRob
Great, thank you
Post #719417 24th Jul 2018 11:07am
Balvaig
Whilst you have the plug off the motor put your circuit tester on the plug, operate the switch, and check for 12v.
Post #719427 24th Jul 2018 12:04pm
expatRob
Good idea
Post #719429 24th Jul 2018 12:09pm
zsd-puma
......While wiggling the cable tube between the door and the car - see if the voltage is constant.
Post #719431 24th Jul 2018 12:10pm
