Home > Puma (Tdci) > Passenger power Window failure |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Put a live feed direct to the motor, it will confirm if it’s the motor or the loom,
99% of the time it’s the door loom that’s at fault. Did you test the loom, or just visually look at it? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
24th Jul 2018 9:27am |
As cars go stripping the door down on a Defender is one of the simplest. It's worth buying the foam water shedder for inside the door, they're cheap from Land Rover. It's much easier than trying to salvage the old water shedder and adhesive.
And a trim removal tool for the door card clips will greatly reduce the chances of damaging the door card. |
24th Jul 2018 9:28am |
expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58 |
No sir, I did not test the Loom, I do not know how to do that. I have a good tester can you tell me how to test it? Also how do I put a "Live feed" to the motor? I appreciate your guidance, I am new and learning. |
24th Jul 2018 9:58am |
Strip the door down, unplug the motor, then connect the motor directly to a battery with a couple of bits of wire. If the motor works, you know it's the switch or wiring harness at fault. |
24th Jul 2018 10:02am |
Great, thank you
24th Jul 2018 11:07am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 735 |
Whilst you have the plug off the motor put your circuit tester on the plug, operate the switch, and check for 12v.
24th Jul 2018 12:04pm |
Good idea
24th Jul 2018 12:09pm |
......While wiggling the cable tube between the door and the car - see if the voltage is constant. |
24th Jul 2018 12:10pm |
