Home > Puma (Tdci) > 2.4 service
Jim1988
2.4 service
I will be buying service items on Tuesday to service my car at home, I will also be changing the oil seal from the diff to the prop, I’ve looked around in the search for compatable oils etc, but they all seem to be for the 2.2.
If anyone can advise what oils and filters I need. Plus what the proper name for the seal is. It’s the front axle/diff.
I assume I need oil for,
Gear box
Transfer box
Engine
Front and rear diffs
Filters for oil and air, do we change the fuel filter? Or are they life time in the tank?
I do have air con, do we have a pollen filter?
And do I need any “special tools”
Many thanks in advance. Regards Jim Thanks Jim.
Post #718927 21st Jul 2018 3:51pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
The above might be a scan of the oils bit of my 2.4 manual
Post #718944 21st Jul 2018 4:44pm
shropshiredefender
Gosh it worked!
The oil seal is the differential nose (pinion) seal.
If you do a search on here it will give you tips and hints etc.
Have fun Thumbs Up
Last edited by shropshiredefender on 22nd Jul 2018 11:43am. Edited 1 time in total
Post #718945 21st Jul 2018 4:48pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
That Bot130m stuff for the transmission is no longer available, the equivalent is Castrol Syntrans Multivehicle 75w90
For the transfer box you can use Castrol Syntrax Longlife 75w90
Post #718966 21st Jul 2018 6:27pm
Jim1988
That’s great guys thank you 🤗
Looking forward to doing this my self, always get a nice feeling (after) it’s finished lol, as if you appreciate it more, and you get the added bonus of knowing everything has been done. Thanks Jim.
Post #719000 21st Jul 2018 9:06pm
agentmulder
Kuwait
Or BOT328 Thumbs Up Solved the bowel problem, working on the consonants...
Post #719029 22nd Jul 2018 2:03am
dorsetsmith
Post #719055 22nd Jul 2018 9:07am
Jim1988
Thanks that will be a big help Thanks Jim.
Post #719158 22nd Jul 2018 8:32pm
