Home > Puma (Tdci) > Output shaft failure, Forum Survey |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1400 |
To start us off,
1, vehicle year of manufacture 2015 2, engine type 2.4 or 2.2, 2.2 3, is the Defender still running with the original output shaft? (Y/N) Y 4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. 18 000 miles If the shaft has previously failed, please answer 5 & 6. 5, Has an Ashcroft modified part has been fitted? (Y/N) Not applicable 6, vehicle milage at the second failure, or milage if still running. Not applicable Comment. Still on original shaft at 3.5 years old, 18000 miles, no noticeable driveline noise or issues. |
11th Jul 2018 9:56pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
1. 2008
2. 2.4 3. Don't know. I havent changed in during my 3 year ownership 4. No failure (as far as I am aware) now 31,000miles |
11th Jul 2018 10:44pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
1. 2007
2. 2.4 3. Y 4. 55k miles Puma 110" SW ............................................................. Earth first. Other planets later |
11th Jul 2018 11:02pm |
Oz Paul Member Since: 12 Jul 2018 Location: Perth Posts: 1 |
1. 2012
2. 2.2l 3. Yes 4. 140,000km (87,000 miles) Daily driver, never gets pushed too hard on or off road. My clutch is rattling so when that gets replaced I will probably get an Ashcroft output shaft fitted. |
12th Jul 2018 3:41am |
1. 2010
2. 2.4 (obviously) 3. N 4. Shaft didn't fail I replaced it with an Ashcroft kit when the clutch was done at 82'000miles as a precaution 5. Yes 6. hasn't failed again, at 87'000 |
12th Jul 2018 3:49am |
rtg Member Since: 25 Jun 2014 Location: UA Posts: 10 |
1, 2009
2, 2.4 3, No, shaft was replaced at about 140.000km while replacing the clutch. It showed signs of wear. 4, - |
12th Jul 2018 4:55am |
justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167 |
1, 2012
2, 2.2 3, Y 4, 50K miles Now gone - 2012 2.2 110 DC XS |
12th Jul 2018 5:56am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
1, vehicle year of manufacture: 2009
2, engine type 2.4 or 2.2: 2.4 3, is the Defender still running with the original output shaft? (Y/N): Yes 4, vehicle milage at first shaft failure, or current milage on the original shaft if still running: 137.000 miles (220.000km) |
12th Jul 2018 6:37am |
skoller Member Since: 27 Oct 2011 Location: australia Posts: 7 |
2009
2.4l no 100,000k shaft replaced with Ashcroft. On inspection of original shaft, replacement was just in time. |
12th Jul 2018 7:45am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
1, vehicle year of manufacture: 2012
2, engine type 2.4 or 2.2: 2.2 3, is the Defender still running with the original output shaft? (Y/N): No 4, vehicle mileage at first shaft failure, or current mileage on the original shaft if still running: 35,000miles 5, Has an Ashcroft modified part has been fitted? (Y/N) No (warranty replacement) 6, vehicle mileage at the second failure, or mileage if still running. 45,000 (still running) Keith |
12th Jul 2018 7:57am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
2011
2.4 No Failed at 85,000 replaced with genuine part. 2008 (mine) 2.4 No Replaced along with clutch at 90,000 (grease nipple fitted to coupling) Genuine part. 2015 2.2 No Failed around 27,000 replaced with genuine part. 2010 2.4 No Failed at 53,000 replaced with genuine part. 2010 2.4 No (Rusty but ok) 62,000 replaced with clutch, genuine part. 2009 2.4 No (rusty but ok) 59,000 replaced with clutch, genuine part. All tow heavy loads for a living. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
12th Jul 2018 8:12am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2298 |
1. 2007
2. 2.4 3. N 4. Shaft didn't fail I replaced it with an Ashcroft kit as a precaution when the clutch was done at 75,000 miles 5. Yes 6. Current mileage 79,000 |
12th Jul 2018 8:21am |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
1, 2010
2, 2.4 3, No 4, 59k 5, No 6, 60K My 90 Project : http://www.defender2.net/forum/topic52774.html |
12th Jul 2018 9:06am |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 |
1, 2008
2, 2.4 3, Si 4, 220.000 Km (136.701 Millas) |
12th Jul 2018 9:27am |
