![]() | Home > Puma (Tdci) > Battery Terminals |
Hello folks,
Has anybody fitted better battery terminals? The existing ones on mine are impossible to tighten up properly. No matter how tight I do the nuts, it's still possible to move the terminals on their posts. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks. There's nothing wrong with the battery posts. It's the original LR battery and it's in good condition. I quite like the idea of wrapping some thin steel around the posts to pad them out but I would be interested to hear if anybody has replaced them with something more conventional. Darren
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
I had the same issue when replacing the battery recently! I found tapping the terminal bracket onto the lead terminal with a small hammer helped a lot, make sure you don’t clonk the terminal though as removing it might then be difficult......the terminal brackets did then tighten securely....... 2008 TDCi 2.4 XS CSW |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
That's why I suggested putting a socket over the terminal, get one just larger than the battery post and it drives the terminal not the post. ![]() |
I've fitted these to replace the pressed steel ones (which always distort) on other cars.
https://www.autosparks.co.uk/electrical-co...-0-30.html They're easy enough to solder on, then you can put some heat shrink over the cable join to make it neat. But I'm still not sure what you'd do with the positive terminal. |
Solved the problem this morning. Made some shims, from copper rather than steel as it was easier to work with, and it's worked a treat. Thanks for the idea
![]() http://www.defender2.net/forum/post716692.html#716692 ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
I replaced my negative clamp with the type with a 10mm stud that accepts a 10mm cable lug crimped onto the negative cable to makes wiring accessories easier, such as my negative winch cable. I didn’t actually have a problem with lack of tightness on the battery post on the Puma but used the copper shim solution on my Son’s 300tdi to good effect. 2010 Defender 110 Station Wagon, Santorini Black.
Actually I hadn't thought of cutting a bit off some copper pipe, better than steel.
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
I have replaced mine with this one (it is from Iveco Daily):
https://goo.gl/images/aXkgrM The original one was too loose, not possible to tight anymore. Janusz www.yahodeville.com |
