Home > Tdi > Running hot? |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 631 |
Seems absolutely fine to me on a warm day on a run, especially motorway. JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
8th Jul 2018 7:12pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Have you got the correct sender unit and gauge,? i.e. if it was a n/a I think there are are problems matching up the readings!
8th Jul 2018 7:24pm |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 |
I have a non OEM unit fitted 1990 200tdi conversion 90
8th Jul 2018 7:38pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
That sounds perfectly with normal from my experience.
8th Jul 2018 8:04pm |
matthamiltonusa Member Since: 25 Jun 2018 Location: Nashville, TN Posts: 2 |
I have the same concern with my 1993 Defender 110 200 Tdi. Really hot day on the motorway with the Air con my temp gauge will get really close to the far right edge of the white arc.
What's are the first three items you all would do to try and get the temps lower? 1. Larger intercooler? 2. Replace the cheap parts like temp sender, thermostat, silicon hoses, radiator flush 3. Other ideas?????? 1995 Disco V8 1995 Defender 130 300 Tdi 1993 Defender 110 200 Tdi 1981 Series III 109 Cargo |
10th Jul 2018 10:09pm |
If its in the white bit its OK - nominal, within parameters. So in the confidence that it had a healthy, flushed cooling system with a fully-opening thermostat I'd be happy.
I would add that modern temp gauges mislead drivers by reading in the middle across a range of actual temperatures. Between approx 85 and 110 degrees they will read dead middle - and only rise or fall outside of those temps. Very different from the analogue scale you see on an old school landy. JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
11th Jul 2018 7:09am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20302 |
Depends how old the coolant is but change it. I’ve always found ore mixes to be more efficient. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
11th Jul 2018 10:53am |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 |
Also check the plastic bung/cap on the rad, mine was tight but had been over tighten by previous owner and split stopping the system from pressurizing correctly and used to cause it to run hot when towing up hill or on a hot day. 2008 Defender 110 XS CSW
Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
11th Jul 2018 11:07am |
Edit* Typo. I meant pre mix coolant* ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
11th Jul 2018 11:25am |
