Home > Puma (Tdci) > Headlight flash |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Probably the switch toasted
5th Jul 2018 5:11pm |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 208 |
Maybe i'll pull it apart and have a look, it works forward just not back!
5th Jul 2018 5:12pm |
No one else have any ideas before I pull it apart?
7th Jul 2018 4:05pm |
As suggested, it's likely the switch - that's the horn/main beam/indicator stalk. Darren
7th Jul 2018 4:22pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20355 |
Bridge the switch carefully. If it works it’ll be the culprit and buy a new one.
If not the issue is elsewhere $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Jul 2018 4:49pm |
I bought a new one incase the old one was toast but on inspection
I didn't realise these were still so basic! A 30 second fix! I now don't need the new one! |
27th Jul 2018 3:16pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Unfortunately the stalk still has all the headlamp current running through it so it's only a mater of time before it fails.
More so if you swap between main and dipped lamps at night. This is why I fitted a good quality aftermarket relay/loom up grade kit. Cheers, Kyle. |
29th Jul 2018 12:31am |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Landreiziger loom time too I'd suggest. Shouldn't have another stalk pop again, with the added benefit of brighter lights! (If you're using halogen of course)
Thinking about it, I presume you are using halogens, as LEDs should ever pull enough juice to pop the stalk.. What was the fix you did to get it working? |
29th Jul 2018 12:35pm |
It hasn’t gone pop! As I said in the earlier post a 30 second fix! It was just a build up of fluff between the contacts! A quick blast with the air line and fixed! And yes, I’m running speaker led’s.
29th Jul 2018 12:57pm |
Ah apologies! I misunderstood. I assumed you meant you'd freed up the contacts that usually weld themselves shut or something!
Yeah those LEDs should be pulling enough current to really bother the switch. |
29th Jul 2018 1:17pm |
