Home > Puma (Tdci) > Headlight flash
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Headlight flash
More electrical issues Big Cry
Having sorted the blown 30amp fuse for the lights I now have no headlight flash!
The Haynes manual says that again it's under the seat is 20amp and is horn/headlamp flash, however, on the fuse cover it just says horn and the horn is working fine!
Could it just be a faulty stalk assembly?
Any ideas gratefully received..
It's a 2011 2.4 DCPU.
Post #716289 5th Jul 2018 5:09pm
williamthedog
Probably the switch toasted Neutral
Post #716291 5th Jul 2018 5:11pm
Pinky
Maybe i'll pull it apart and have a look, it works forward just not back!
Post #716293 5th Jul 2018 5:12pm
Pinky
No one else have any ideas before I pull it apart?
Post #716599 7th Jul 2018 4:05pm
As suggested, it's likely the switch - that's the horn/main beam/indicator stalk. Darren
Post #716601 7th Jul 2018 4:22pm
Bridge the switch carefully. If it works it’ll be the culprit and buy a new one.
If not the issue is elsewhere TheThunder Rolls🇬🇧🇺🇸
Post #716604 7th Jul 2018 4:49pm
Pinky
I bought a new one incase the old one was toast but on inspection
I didn't realise these were still so basic! A 30 second fix!
I now don't need the new one!
Post #719976 27th Jul 2018 3:16pm
Alien
Australia
Unfortunately the stalk still has all the headlamp current running through it so it's only a mater of time before it fails.
More so if you swap between main and dipped lamps at night.
This is why I fitted a good quality aftermarket relay/loom up grade kit. Cheers,
Kyle.
Post #720142 29th Jul 2018 12:31am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Landreiziger loom time too I'd suggest. Shouldn't have another stalk pop again, with the added benefit of brighter lights! (If you're using halogen of course)
Thinking about it, I presume you are using halogens, as LEDs should ever pull enough juice to pop the stalk.. Thumbs Up
What was the fix you did to get it working?
Post #720208 29th Jul 2018 12:35pm
Pinky
It hasn’t gone pop! As I said in the earlier post a 30 second fix! It was just a build up of fluff between the contacts! A quick blast with the air line and fixed! And yes, I’m running speaker led’s.
Post #720217 29th Jul 2018 12:57pm
BenB8man
Ah apologies! I misunderstood. I assumed you meant you'd freed up the contacts that usually weld themselves shut or something!
Yeah those LEDs should be pulling enough current to really bother the switch. Thumbs Up
Post #720223 29th Jul 2018 1:17pm
